Compensator - How does it work??? - Road Glide Forums
post #1 of 8 (permalink) Old 01-24-2014, 08:20 PM Thread Starter
1st Sgt's Avatar
Would someone explain to me how the compensator actually works. I would have thought a simple sprocket attached to the output shaft would provide the power to drive the primary chain. But with reference to compensators "going bad", pitted ramps, etc. Clearly there is more to it than a sprocket to drive a chain.
1st Sgt is offline
post #2 of 8 (permalink) Old 01-24-2014, 08:30 PM
Stray Mutt's Avatar
I think in your simple (though logical) design, the concern is sudden tension in the train of components, which ends up being absorbed by the chain. Only so many of those jolts can be sustained until something gives. The compensator sort of smooths that out. Here's a pretty good explanation in layman's terms.
http://www.ask.com/explore/compensat...vidson-do-4852
Stray Mutt is offline
post #3 of 8 (permalink) Old 01-24-2014, 09:04 PM Thread Starter
1st Sgt's Avatar
Dude - Thanks for the explanation and the link - now it makes sense
1st Sgt is offline
post #4 of 8 (permalink) Old 01-26-2014, 08:26 AM
Thermodyne's Avatar
As said above, it's a cushion. It absorbs the torque pulses and then releases them. The energy is stored in the plate springs.
It's not so much for protecting the chain as it is for protecting the transmission gears. Automobiles use coil springs in the clutch hub for the same reason.
Thermodyne is offline
post #5 of 8 (permalink) Old 01-26-2014, 08:41 AM
mitchdm's Avatar
The simple sprocket is the way I went ~ Vulcanworks and love it. I have replaced 7 compensators on two bikes in 4 years with a combined 120k on the clocks ~ this was ridiculous. The vulcanworks sprocket will probably never need replacement.
mitchdm is offline
post #6 of 8 (permalink) Old 03-26-2014, 05:07 PM
Is the vulcan gear (part number if you have) all that you changed?
gaspumpcity is offline
post #7 of 8 (permalink) Old 03-26-2014, 06:02 PM
skototrot19's Avatar
Good stuff! Thanks Straymutt!
Sent from Motorcycle.com App
2013 RGU Vivid Black. Madstad, long stemmed black mirrors, BRIGHT ASS LIGHT on the rear, Sirius dock, De-cat Header, Jackpot Slash-Up Mufflers (BLACK), Fuel Moto Micro Tuner, Custom Dynamics LED turns, and Attitude adjusted with Mean Mug! Slowly but surely turning all the shiny bits BLACK!
skototrot19 is offline
post #8 of 8 (permalink) Old 03-28-2014, 05:59 AM
mitchdm's Avatar
34T Motor Sprocket, 06+ Dynas, 07+ Softails, Dressers
For 2006+ Dynas, 2007+ Softails, Dressers, T/C-96 A & B Motors
Solid sprocket conversion to eliminate compensator assembly.
Eliminates slippage and noise from compensator.
Made from 4140 Tool Steel & Heat Treated.
Part# 4513
http://vulcanworks.net/Motor-Sprocke...0-p-1-c-6.html
Many other components have been replaced. The only way to eliminate compensator failure is to eliminate it. I do not lug the bike and don't "shock the crank". This has been a welcome addition to a RG that is ridden 40+k per year.
mitchdm is offline
New Compensator or Compensator eliminator mrmoto95 Engine Related 11 03-28-2018 07:10 PM
What does a failing compensator look like thedrill Engine Related 19 01-27-2014 10:00 PM
Does parade mode still work with the thundermax? Cgault99 *General Road Glide Discussions/Pictures 2 06-14-2012 08:00 PM
Does ABS work... BLKNCr6 Videos 2 09-10-2011 05:13 PM
How does the headlight Cover on older models attach? Will one work on a 2010? DED HD *General Road Glide Discussions/Pictures 9 07-21-2011 08:34 PM
