Fairing mount question - Road Glide Forums
post #1 of 7 (permalink) Old 02-18-2014, 07:37 PM Thread Starter
ddm502001's Avatar
For the techs:
We bought or 2012 new and it always had a seeming tilt to the fairing based on the radio extension area alignment to the gauge head on the triple tree, am I seeing things or is there a alignment process to make certain it is square to the bike?
ddm502001 is offline
post #2 of 7 (permalink) Old 02-18-2014, 07:42 PM
OldNerdGuy's Avatar
Not sure about a process, but you can adjust the fit. The easiest is to loosen the mounts on the Engine Bars and move them around. Not much play there, but enough to tweak it. The serious adjustments require taking the outer fairing off and adjusting the 4 bolts that mount the inner to the frame. If you've never taken the outer off, it's a treat. Plenty of threads on that process to be found on here.
OldNerdGuy is offline
post #3 of 7 (permalink) Old 02-18-2014, 09:22 PM
faststan's Avatar
As ONG said you need to take your fairing off and adjust the 4 bolts that hold the inner fairing on. Be sure to mount the crash bar mounts to get the correct fit. Plenty of interesting things under the outer fairing. You can look at your speakers and figure out what a piece of cake it is to change speakers and look at all the room in there. You could use an amp, some more lights, and, and, and.
Mine was maladjusted when I got it too.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #4 of 7 (permalink) Old 02-23-2014, 09:38 AM Thread Starter
ddm502001's Avatar
Thanks guys, had been considering just pulling the outer and trying to square it up line of sight but worried there was a process with these. I had it out yesterday and as stated it seems worse than when bought, can they shift over time? I am going into it today to see what I can as to what is going on in there.
Dave
post #5 of 7 (permalink) Old 02-23-2014, 10:21 AM
I had the same problem when I first bought my bike, I watched the tech at the dealership remove the fairing and adjust it, (of course it was covered under warranty) since then I've done it myself. Once you get familiar with removing and replacing the outer fairing it's pretty simple.
Sent from my SPH-L710
post #6 of 7 (permalink) Old 02-23-2014, 10:33 PM
rageglide's Avatar
First thing I'd do is sit on the bike with a bullet level and put it on the top of the speedo/tach pod. Level it. Then move it to the top of the radio bulge... what's it say? When the radio pod is level, what's the windshield look like? I think much of the complaints are due to the Windshield sittin' crooked. Behind that, I think many folks sit side-saddle by nature. I know my jeans leave a mark on the seat that's off center of the seat when I get off the bike.
2012 fltrx
rageglide is offline
post #7 of 7 (permalink) Old 02-23-2014, 11:45 PM
Lucky D's Avatar
Well , hell.
I thought I was seeing things when it looked like things wernt exactly square with the fairing / radio !
I was needing to get inside and tinker with my amp anyway.
... Chrome?? We donneeedno stiinnkinng chrome.
Lucky D is offline
Smartphone mount besides my Iron Aces GPS mount SEsupply2 Audio 12 01-05-2014 06:33 PM
Mount or no mount for PV Boxercop ECM/Fuel Management systems 14 07-04-2013 11:31 AM
10" Windvest. front and rear turn signals. Rear mount and pegs and highway peg mount. 1346wildcat Parts for Sale 10 04-23-2013 06:34 PM
WTB: 2 up detach tour park mount and solo tour pak mount for 09+ bikerglasses Wanted! (Buy or Trade) 2 04-01-2013 10:22 AM
Top mount vs bottom mount in fairing? SickRick Audio 5 12-30-2011 01:28 PM
