Belt too loose - Road Glide Forums
post #1 of 12 (permalink) Old 02-28-2014, 07:07 AM Thread Starter
1st Sgt's Avatar
Belt too loose
I just got back from the races at Daytona and while cleaning the mud off the bike I found that my final drive belt was WAY loose. I measured it both on a jack and on the ground (jiffy stand) and had over an inch of deflection. I never heard or felt anything odd so I was wondering if anyone here has actually had a belt loose enough to rachet on the sprocket and if so; were you able to feel or hear it?
I didn't see any damage to the belt but was still wondering.
1st Sgt is offline
post #2 of 12 (permalink) Old 02-28-2014, 10:22 AM
unless the check changed on the newer bikes my 01 says to check belt tension with weight on the bike equal to riders weight or as close as you can get.
Eagle
Eagle is offline
post #3 of 12 (permalink) Old 02-28-2014, 10:31 AM
How would the weight on the bike affect the tension on the belt? Anyway I check my tension when I change the oil and always about 1k after a tire change. Last year right before SWIII I had to tighten it, but I don't think I had over an inch of deflection, good thing you caught it before any damage was done.
Sent from my SPH-L710
post #4 of 12 (permalink) Old 02-28-2014, 10:33 AM
PGR
PGR's Avatar
Eagle
That has changed...... from the 2011 manual:
With motorcycle upright and rear wheel off the ground or on jiffy stand without rider or luggage.
Ron..........................
PGR is offline
post #5 of 12 (permalink) Old 02-28-2014, 11:32 AM
skratch's Avatar
even though the procedure is different, your question still deserves an answer.
the belt will tighten when the swingarm is raised up, ie. when weight is put on the rear suspension. if you put shorter shocks on the rear, you'll notice that the belt tension will increase then as well.
skratch is offline
post #6 of 12 (permalink) Old 02-28-2014, 11:43 AM
Thanks skratch, I thought about it afterwards and that's about what I came up with also, you answer clarifies that for me.
post #7 of 12 (permalink) Old 02-28-2014, 03:36 PM
Skratch beat me to it , but that how it was explained to me , and how I check mine .
Eagle
Eagle is offline
post #8 of 12 (permalink) Old 02-28-2014, 04:02 PM
Well hell then explain the air shocks? Could be wise there's that a belt tensioning measuring thing or not
reds4 is offline
post #9 of 12 (permalink) Old 02-28-2014, 04:09 PM
Or if you still have your belt gaurd on has that window, at least on the older models
Yes have heard the belt make flapping sound, you have to be just rear to the left dropped from side-by-side to hear your buds belt if to loose
reds4 is offline
post #10 of 12 (permalink) Old 03-01-2014, 12:31 PM
Mine also was REALLY loose once but, it never did slip or made a noise. Yet, I could "feel" it. I purchased a couple tools from Amazon, followed the service manuel and all is good. This is an easy fix.
Churping Sound / Rear Belt Keeps coming loose? gslobo New Members Welcome Area 1 08-24-2017 07:32 AM
Too cold to Roadglide, too warm to snowmobile, what to do? mike General Off-Topic Discussions 8 01-18-2014 10:30 AM
Too loose and too tight Howardsternspenis Do-IT-Yourself 12 06-13-2012 01:07 PM
Never again loose a wellnut in your faring BDMastiff *General Road Glide Discussions/Pictures 9 10-05-2010 10:38 AM
2010 loose duel headlights bigtwin Lighting 6 04-25-2010 09:16 PM
