Oil on air filter - Road Glide Forums
post #1 of 3 (permalink) Old 12-04-2011, 08:22 PM Thread Starter
dwighop's Avatar
Oil on air filter
After washing the bike today took it for spin. When I stopped i noticed some oil from the filter. What if anything would cause that?
dwighop is offline
post #2 of 3 (permalink) Old 12-04-2011, 09:44 PM
Triplej's Avatar
It is a fairly normal occurrence if you run the oil close to the top of the full mark especially if you ride it hard. If this is the case try running with the oil about halfway down the full marks and see if that helps. I run mine between 1/2 and 1/4 full on the dipstick.
Also if you have re-oiled a Stage 1 A/F recently it can be normal to see some oil drip then as well.
As long as it is not excessive it is probably nothing to worry about.
Triplej is offline
post #3 of 3 (permalink) Old 12-05-2011, 03:44 AM
Radioactive's Avatar
+1 on the oil level. I only put 3 qts in mine on oil changes.
Radioactive is offline
K&N Filter vs.HD Oil Filter RRHartzler Fluids and Lubricants 49 10-22-2016 08:00 PM
Removing oil filter with oil cooler 02heritage *General Road Glide Discussions/Pictures 17 05-12-2014 12:10 AM
oil smell & oil in air filter fat boy ultra Troubleshooting for Road Glides 6 04-11-2013 11:04 AM
Oil in Air Filter....the Cause?? Nevadasun *General Road Glide Discussions/Pictures 2 11-02-2011 07:08 PM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 12:38 PM
