Tranny swap - Road Glide Forums
post #1 of 2 (permalink) Old 01-29-2012, 09:44 PM Thread Starter
06 Rider's Avatar
Tranny swap
I'm trying to verify some technical info. Anyone see a problem or hear of issues with using a 2002 FLT tranny in a 2006 frame. I would think it would be a direct bolt except maybe for a vent line to the filler neck, whick can be solved by swapping filler necks.
I want to use a baker 6 speed gear set in that also. Anyone know of any issues with that? Is there case clearancing or anything that is required for that? Thanks for the comments in advance.
06 Rider is offline
post #2 of 2 (permalink) Old 01-29-2012, 10:04 PM
I would give Baker a call they have a very good customer service department and they could give you the straight skinny.
jeff is offline
HELP?? Tranny bolts loosened up after long ride home!! Ma$$hole *General Road Glide Discussions/Pictures 19 07-30-2015 11:33 AM
Engine and tranny swap burph Engine Related 4 01-16-2013 11:16 PM
Tranny bearing causing clutch slippage NoBull Road Glide Specific Discussions 9 12-01-2011 05:06 PM
The dreaded loose tranny bolts PGR Intake and Exhaust 4 10-18-2011 09:35 AM
Painting motor and tranny GordonC Engine Related 2 04-22-2011 05:58 PM
