Front fork holder bolt threaded shaft - Road Glide Forums
post #1 of 2 (permalink) Old 05-15-2014, 08:47 PM Thread Starter
Help... the holder bolt thread shaft sheared off when I loosened and retightened when I was reinstalling new rubber on front wheel. I over torqued it! Is the threaded shaft removable and replaceable. if so is it a left thread to install. I hope I don't have to weld it and re-thread.
Help...
djdenniston2014 is offline
post #2 of 2 (permalink) Old 05-15-2014, 09:05 PM
Are you talking about the two threaded studz that come out of the bottom of the slider ? If so , yes . They come out and can be replaced.
Use heat and a double nut to remove. If you dont have enough thread , weld a nut on to remove.
Threaded Insert for seat bolt tlottman Seating: seats, backrests 9 05-21-2015 12:30 PM
Bent Main Shaft laserman Engine Related 2 10-09-2014 08:19 PM
Shifter shaft lever problems DED HD Troubleshooting for Road Glides 24 09-13-2013 12:28 PM
Bropken and missing tabs and threaded holes on outer fairing? HogPro Paint & Bodywork Section 2 07-30-2013 05:58 AM
Upper Frame Threaded Hole Rust Prevention john218 Do-IT-Yourself 6 02-03-2011 07:50 AM
