Security System - Fob - Road Glide Forums
post #1 of 11 (permalink) Old 06-07-2014, 11:38 AM Thread Starter
2007 RG Stage 1, 9800 mi 2nd owner. looking for advice on using security fob. I have replaced the batteries in the fob and the on bike security system does not seem to pick up the signal from the fob. Where is the antenna on the bike located? Can I move the on bike pick up to a location that will allow me to match the fob to the location so I do not have to look like I am having spasms moving the fob around so the bike will pick up the fob signal? enjoying the ride but getting frustrated with the security. It's so secure that I cannot even start my ride. Thanks in advance.......
Chico1960 is offline
post #2 of 11 (permalink) Old 06-07-2014, 01:39 PM
JacktheBagger's Avatar
have you checked the battery in the security system , the antenna is under the seat with the security system ..
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 11 (permalink) Old 06-07-2014, 02:50 PM Thread Starter
I found the antenna and the tssm. Does the tssm have a battery inside?
What is the correct procedure to open tssm?
post #4 of 11 (permalink) Old 06-07-2014, 03:29 PM
FDR's RGC's Avatar
Not inside the tssm. Look behind it. A thread here says there is a 9 volt rechargeable battery there.
Search tssm.
FDR's RGC is online now
post #5 of 11 (permalink) Old 06-07-2014, 07:59 PM
The 9 volt battery is in the siren module if you have one .
Eagle is offline
post #6 of 11 (permalink) Old 06-07-2014, 09:06 PM
Is the battery there only if you have an audible siren?
post #7 of 11 (permalink) Old 06-07-2014, 09:34 PM
That is my understanding, that way even if someone disconnects the main battery in the bike the siren will still sound .
Eagle is offline
post #8 of 11 (permalink) Old 06-08-2014, 01:03 AM
skratch's Avatar
if you're having problems with the fob, first, check the batteries. i know you said you replaced them, but it seems that 9 times out of 10, they were installed upside down.
if you're still having problems, are you sure it is a good battery? sometimes they come off the shelf already bad.
then, do you know your override code? do you know how to use it? if yes, then at least you'll be able to ride while you troubleshoot the system. and you will only have a backup battery if you have the audible alarm installed.
skratch is offline
post #9 of 11 (permalink) Old 06-08-2014, 08:57 AM Thread Starter
New day
From the research I have been doing online I am taking the following steps:
1) Disconnect 12v main battery, put on trickle
2) Remove 40 amp "Big Orange Fuse/Breaker"
3) Replace FOB Battery, this may be where the problem has originated,
There are 2 slim batteries - where it appears there should be a single thick button battery.
4) Reinstall Battery
5) Reinstall Big Orange
6) Reset Security System with a On-off switch Turn Signal dance from the MOCO.
7) Reset personal bypass code.
plan your work, work your plan
post #10 of 11 (permalink) Old 06-08-2014, 09:57 AM
There should only be 1 battery in the FOB so that may be your problem.
I believe to reset the bypass code you must have a working FOB.
Security fob failed! RonC26 General Off-Topic Discussions 28 12-05-2016 04:45 PM
Security fob issue in Daytona Deadstroke *General Road Glide Discussions/Pictures 4 03-13-2016 09:09 PM
Security fob LL Cool K Wanted! (Buy or Trade) 12 08-20-2012 09:59 AM
Passive Security System (Key Fob) blacktopr Troubleshooting for Road Glides 7 08-29-2011 10:08 PM
FOB Security set up question Russian Road Glider *General Road Glide Discussions/Pictures 10 08-26-2011 04:27 PM
