Clutch Handle Adjustment - Road Glide Forums
post #1 of 16 (permalink) Old 06-11-2014, 11:55 AM Thread Starter
DanHappy's Avatar
Guys,
Since I got the bike and been riding it, I want to adjust where the clutch handle engages and disengages. The handle now starts to grab at about half way out. Total grab is almost fully out. I buddy of mine mentioned to adjust the cable slack on the cable going down the frame. Is that the correct thing to do? I want it so, when squeezed in, to start to grab allot sooner than it is now. Any help?
Thanks in advance.
DanHappy is offline
post #2 of 16 (permalink) Old 06-11-2014, 12:21 PM
Bluchevypick's Avatar
That is infact where you adjust the throw at.
Bluchevypick is offline
post #3 of 16 (permalink) Old 06-11-2014, 12:24 PM Thread Starter
DanHappy's Avatar
So I just adjust the throw there and I don't have to worry about going into the clutch at all?
Good. Easy.
DanHappy
DanHappy is offline
post #4 of 16 (permalink) Old 06-11-2014, 02:34 PM
rageglide's Avatar
Engagement point is adjusted with the adjuster on the clutch pressure plate. Cable adjustment adjusts lever slop.
You didnt say what year, but I've found the later 6 speeds to need more disengagement travel to insure you get adequate plate seperation, if not you get drag and drag makes harsh first gear engagement and neutral tough to find.
2012 fltrx
rageglide is offline
post #5 of 16 (permalink) Old 06-11-2014, 02:48 PM Thread Starter
DanHappy's Avatar
It is a 2013. So if I understand you, i new to adjust both areas?
DanHappy
DanHappy is offline
post #6 of 16 (permalink) Old 06-11-2014, 03:13 PM
What rageglide said. You adjust where the hand lever grabs , in the primary, on the pressure plate. Then adjust on the cable to remove slope in cable. The cable adjustment should be about the same on all bikes. About 1/8 " of lever play (slop).
post #7 of 16 (permalink) Old 06-11-2014, 04:29 PM Thread Starter
DanHappy's Avatar
Anywhere I can get directions so I don't F it up? Never worked on a bike before and I don't want to "poke and hope".
DanHappy
DanHappy is offline
post #8 of 16 (permalink) Old 06-11-2014, 05:51 PM
I would strongly recommend getting the service manual for your bike. Search on YouTube I think I remember seeing a video on the clutch pack adjustment.
2012 FLTRX
Sideways is offline
post #9 of 16 (permalink) Old 06-11-2014, 06:00 PM Thread Starter
DanHappy's Avatar
Good idea. Will check. Thanks guys.
DanHappy
DanHappy is offline
post #10 of 16 (permalink) Old 06-11-2014, 06:56 PM
Pattywagon's Avatar
Loosen cable adjuster all the way , so u have a lot of slop in clutch handle. Then take off primary inspection cover , loosen lock nut on clutch adjuster , loosen inner screw out a couple rounds, then slowly tighten back in till u feel tension n then back off 1/4 to 1/2 turn . Hold inner adjuster screw n lock down outer nut . Done with clutch adjustment . Next go back to cable tighten till u have about 1/8 to 1/16
(SLOP) in clutch lever. DONE!!!
You tube is ur friend, just type in harley clutch adjustment , if u need more help.
2013 FLTRX,8inch klockwerks,CFRknockoffs,11inch CC apes, screamin eagle 255 cams n adjustable pushrods, PC5, DYNOED 85.5 HP, 104 torque,SoCal HID's
Pattywagon is offline
2012 clutch adjustment cloud Tech Area 4 07-18-2012 09:37 AM
Clutch Adjustment jimmyray11349 Troubleshooting for Road Glides 4 07-02-2012 12:38 PM
Clutch Adjustment Tool JayKS Do-IT-Yourself 12 06-01-2012 09:40 PM
Clutch adjustment procedure aviaator Road Glide Specific Discussions 13 07-28-2011 03:38 PM
Clutch adjustment longrides Do-IT-Yourself 5 09-23-2010 10:51 AM
