clunk? - Road Glide Forums
post #1 of 31 (permalink) Old 07-12-2014, 03:53 PM Thread Starter
clunk?
Say I'm in 6th gear at 2000 rpm cruising along in my 2012 FLTRX. If I roll off or on the throttle there is a clunk from below me. I never noticed it before. bike has about 15000 miles on her now. It's weird, like there is some clunky engagement of something. If I pull the clutch lever in and roll off and on the throttle the clunk goes away. What is this???
palmpalm is offline
post #2 of 31 (permalink) Old 07-12-2014, 03:57 PM
Harleyagain's Avatar
Primary chain needs adjustments. Put your bike in 2nd run up the Rpm's to abt 4k then let go of the throttle till it's just abt to stall then pull in your clutch. Just did mine, EZ fix. Would not do it to many times tho. Don't want to over tighten it!
Bob
Harleyagain is offline
post #3 of 31 (permalink) Old 07-12-2014, 04:18 PM Thread Starter
Thanks but nope. Just tried it. Doesn't make a difference.
palmpalm is offline
post #4 of 31 (permalink) Old 07-12-2014, 04:25 PM
Did u try it a couple of times. If that doesn't work you may have other issues. I will let others jump in to help ya...
Bob
post #5 of 31 (permalink) Old 07-12-2014, 04:33 PM
It sounds like you may be "lugging" the engine in that gear at 2k rpm. To me that's a very low rpms to run. Try getting it to make the "clunking" noise at a higher rpms in that same gear.
post #6 of 31 (permalink) Old 07-12-2014, 05:23 PM Thread Starter
Did it multiples times. No change. And it's not gear or Rpm specific. It happens in every gear at every rpm. Just can't hear it so well unless around 2000 rpm because of engine noise. Has nothing to do with lugging the engine.
Harley tech rode it and says it's fine but I suspect he never heard the noise.
palmpalm is offline
post #7 of 31 (permalink) Old 07-12-2014, 10:41 PM
Funny I noticed mine doing the same thing a week or so ago, I have 14k on mine, it doesn't sound like a compensator I know that sound, if I let off the throttle it sounds like the same clunk as if I was shifting gears,
2013 RGU, black of course....
y2kflhr is offline
post #8 of 31 (permalink) Old 07-12-2014, 11:33 PM
Punishher7's Avatar
My 13 seems to do this as well. I was thinking clutch adjustment but haven't checked it yet. I only noticed it recently with about 17500 on the clock. I'll have to wait to get her back to figure it out. It's in a crate on its way to the pacific for a boat ride to HI. I miss it already...
2013 RGC
Punishher7 is offline
post #9 of 31 (permalink) Old 07-13-2014, 08:42 AM
Bruckus's Avatar
On my 13 custom i heard the noise on occasion but not since installing my Hayden m-6 tensioner. Works great for me.
2013 Roadglide Custom - Candy Orange
Drago's Dragula True Duals, Thundermax Tuner
Daymaker LED Headlights, Supershox
Bruckus is offline
post #10 of 31 (permalink) Old 07-17-2014, 05:32 PM Thread Starter
I saw an independent Harley mechanic and I told him about the clunk; he went over to my bike and turned her on, put her in first gear and let the clutch in and out fast and it made the exact same clunking noise! He told me it must be the compensator sprocket. He says he knows that as of 2011 they were updated to the SE compensator on all regular FLTRXs but he says he has seen this before as well even with the SE compensators. He said that on a few he has put in the part made for the Trike system because it's a bit more heavy duty.
palmpalm is offline
Fork CLUNK? glide72 *General Road Glide Discussions/Pictures 19 07-18-2013 05:28 PM
Clunk Sancho Troubleshooting for Road Glides 27 07-17-2012 07:33 AM
ABS Brakes Loud clunk SCARD1 Troubleshooting for Road Glides 3 09-06-2011 12:05 PM
Flexing front end clunk issue joke Troubleshooting for Road Glides 3 04-04-2010 08:05 AM
Annoying clunk/rattle over bumps from front end GizmoGlide *General Road Glide Discussions/Pictures 17 04-01-2010 03:15 PM
