Rear brakes - Road Glide Forums
post #1 of 7 (permalink) Old 08-03-2014, 11:20 AM Thread Starter
Rear brakes
I have a 2005 road glide and think the rear brake pads need to be replaced. How do I do it?
harleyrick2003 is offline
post #2 of 7 (permalink) Old 08-03-2014, 01:05 PM
FDR's RGC's Avatar
By getting a manual and reading it. They come in handy. Push in the pistons using old pads, remove caliper, remove pins holding old pads. Reverse to install. Pump rear brake before riding.
FDR's RGC is offline
post #3 of 7 (permalink) Old 08-03-2014, 01:43 PM
Yes, buy a HD Manual.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 7 (permalink) Old 08-03-2014, 04:38 PM
Definitely get a manual
post #5 of 7 (permalink) Old 08-03-2014, 06:49 PM Thread Starter
Replace rear brake pads
I have a 2005 road glide and the rear brakes will need to be changed soon. It looks like the caliper is mounted on the axle. How do you replace the rear pads.
post #6 of 7 (permalink) Old 08-03-2014, 06:58 PM
Well not to be a dick but go into the new member subforum and introduce yourself to everyone AND THEN start asking your questions. You'll be amazed how much help this extended family can be.
post #7 of 7 (permalink) Old 08-03-2014, 07:34 PM
ERod62's Avatar
Rear brakes
Guess is your first HD...
So here is,
Take the master cylinder cover off with a putty knife pry between the brake pads and the disk unbolt the two small pins and pull the pads replace with new ones, check fluid level and close master cylinder. Pump brake pedal.
Good luck...no need to take the rear tire off or caliper. Invest on the manual. Good source for torque and maintenance work.
Welcome to the forum.
Sent from Motorcycle.com App
ERod62 is offline
rear brakes sj01fltri Do-IT-Yourself 22 05-11-2017 08:51 PM
Rear brakes worn out 14k. Hot rotor seahoch Troubleshooting for Road Glides 11 04-06-2014 12:30 PM
Stunt bike rear brakes throttles&triggers General Off-Topic Discussions 3 01-26-2014 08:49 PM
Tire change = no rear brakes exammo Troubleshooting for Road Glides 11 10-12-2012 04:11 PM
7mm 12 point socket for rear brakes?? Kobrak *General Road Glide Discussions/Pictures 7 04-02-2011 10:29 AM
