Fine Brass particles in drained transmission oil? - Road Glide Forums
post #1 of 8 (permalink) Old 08-05-2014, 10:01 PM Thread Starter
Changed my Transmission oil for the first time after the dealer first service, 4000 miles on the bike now. The drained fluid had what looked like diluted gold metalflake paint on the bottom of the pan with lots of brass fines, almost too small to see without a magnifying glass. What in the transmission is made of Brass? (I'm assuming that is what the gold metal is). There was barely anything on the drain plug magnet, and no chips or shavings at all, just fine filings. Should I be concerned? What could be causing this?
Smopho is offline
post #2 of 8 (permalink) Old 08-05-2014, 10:23 PM
staush's Avatar
brass
New bike? Under warranty? If so, ride it like you stole it.
staush is offline
post #3 of 8 (permalink) Old 08-06-2014, 08:56 AM
Are you sure it was brass? Brass or aluminum is not magnetic so there shouldn't be any on the drain plug magnet, If you still have the old oil run a magnet around it and see if it picks anything up.
The gears and gear shafts along with the bearings are steel and the shavings should stick to your magnet.
Ride the bike for 500 miles and change the trans fluid again and check the oil for metal.
post #4 of 8 (permalink) Old 08-06-2014, 09:25 AM Thread Starter
It is NOT magnetic, and it is gold in color, not silver. Where is brass used inside the transmission. I know it is common on synchro rings in car tranny's, but ours is constant mesh. Is brass used on the shift forks as a wear surface, or are there any brass bushings used?
Smopho is offline
post #5 of 8 (permalink) Old 08-06-2014, 01:47 PM
Thumbs up I Agree, But.
Ride it like you rented it!
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #6 of 8 (permalink) Old 08-07-2014, 08:03 AM
Did you change the Primary fluid at the same time and drain into the same pan? If so, it is probably wear off the primary chain tensioner shoe. I had the same thing in my fluid but it came out of the primary, not the tranny. When I looked at what appeared to be brass with a magnifying glass, I saw that it would break apart when squeezed. It was the hard plastic on the primary tensioner shoe and it looks like brass.
Captain13 is offline
post #7 of 8 (permalink) Old 08-07-2014, 06:13 PM Thread Starter
Drained fluid was not mixed with primary fluid.
Smopho is offline
post #8 of 8 (permalink) Old 08-09-2014, 09:00 PM
smitty901's Avatar
I had that same thing on my 07 never was an issue but at 65,000 a bearing did fail in it. They warrantied it.
Never had any in the 2011 or the 13.
You are right it sure looked like brass
smitty901 is offline
Mystery Brass Threads mrkrtl *General Road Glide Discussions/Pictures 4 10-31-2015 02:27 PM
How about brass or copper? Djtman *General Road Glide Discussions/Pictures 7 04-11-2014 10:28 AM
Brass inserts pulled out of passenger backrest ironmark Seating: seats, backrests 3 10-31-2012 09:48 PM
brass plug size on stock airs hognit Suspensions 3 09-24-2012 04:28 PM
New "retro" RG Whitewalls&Brass nikkidee Road Glide Specific Discussions 27 06-01-2011 09:46 AM
