ABS Rear Brake - Road Glide Forums
post #1 of 14 (permalink) Old 08-11-2014, 07:21 AM Thread Starter
Eric Lis's Avatar
ABS Rear Brake
after switching to 26 Front and 17 Rear developed rear ABS pulsing when coming to a stop. Brake works fine till you get down to around 10 mph then starts pulsing. Front appears to be fine. The ECU to the ABS has already been swapped around with No improvement. I know others that have done this combination with good results. Any ideas?
Eric Lis is offline
post #2 of 14 (permalink) Old 08-11-2014, 10:36 AM
It could be sensing different speeds at each wheel because of the difference in wheel size and causing the ABS to activate. May have a bad sensor too
post #3 of 14 (permalink) Old 08-11-2014, 11:32 AM
The above is only an issue on 2014 ABS models with the linked braking. I'd say a warped rear rotor is the cause.
Drew
HogPro is offline
post #4 of 14 (permalink) Old 08-11-2014, 02:32 PM Thread Starter
Eric Lis's Avatar
Drew, Inwas there when the dealer dial indicated the rear wheel and it was in tolerance. What do you called warped as in thousandths ?
Eric Lis is offline
post #5 of 14 (permalink) Old 08-11-2014, 02:42 PM
Harley spec is .008" for rotor warpage. I don't use my rear often at all. I don;t see how adding a bigger front wheel could affect the rear brake at all Might try changing pads and cleaning out the caliper. Maybe the pistons are sticking due to excessive brake dust build up.
Drew
HogPro is offline
post #6 of 14 (permalink) Old 08-11-2014, 02:47 PM
PGR
PGR's Avatar
Could be a substandard ABS bearing in the wheel.
Ron..........................
PGR is offline
post #7 of 14 (permalink) Old 08-11-2014, 03:05 PM
If there were a problem with the ABS bearing the ABS light would be on. IS it on?
HogPro is offline
post #8 of 14 (permalink) Old 08-11-2014, 03:12 PM
PGR
PGR's Avatar
Not always. Have a friend who changed out his rear wheel and had the same pulsing symptoms. He could feel it in the pedal. Turned out his bearing wasn't putting out a strong enough field. It was strong enough that the ABS light would go out, but the system freaked out when he applied his brake. Even though the wheel wasn't breaking contact with the road, the ABS thought it was skidding.
PGR is offline
post #9 of 14 (permalink) Old 08-11-2014, 03:23 PM
The only issue we have had with that was a the light was on. Bearing was swapped and all returned to normal. I learn something every day. Thanks.
Drew
HogPro is offline
post #10 of 14 (permalink) Old 08-11-2014, 05:06 PM Thread Starter
Eric Lis's Avatar
The wheels came from Renegade with the bearings installed. I opted on their front rotors of which one is out by .012. The rear wheel rotor is the factory one which I installed on the 17 inch rear. I have had intermittent ABS LIGHT along the way since NEW the bike has 3300 miles on it now. Had it to the dealer a couple times and NO codes. All I had to do was stop turn off ignition, turn on again and all was good for the remainder of that day. The problem with the pulsing rear pedal started after swapping the wheels, and perhaps as mentioned it may be in the bearing. All input is much lay appreciated, and these forums are great. Thx guys. Also I would like to mention. It is NOT A runout problem on the disc feeling on the pedal. It is a APPLY and release by the ABS. There is definitely a different pedal feeling between the two. I'm leaning towards the front and rear ABS bearings because the problem wasn't there before the wheel swap.
Eric Lis is offline
Can I put a Abs rear wheel on a non ABS rear? Louster47 Wheels and Tires 10 03-24-2013 10:05 PM
trans klunk when jamming rear brake hard (abs) fat boy ultra Troubleshooting for Road Glides 3 01-29-2013 05:55 PM
To ABS or not to ABS apexlocator Safety Area 33 07-06-2012 09:17 PM
Bonding ABS to ABS or fiberglass? Monkeyman Paint & Bodywork Section 8 04-28-2012 02:16 PM
Changed rear brake arm now almost no rear brake? ncbeast Troubleshooting for Road Glides 4 05-30-2011 09:13 PM
