Oil in the air cleaner.... again - Road Glide Forums
post #1 of 3 (permalink) Old 08-21-2014, 05:46 PM Thread Starter
lonerider's Avatar
Well it happened again lost another air cleaner to oil again third time this season forth time total sense last fall. This time I was 500 miles from home and 550 from the dealer that looked at it 2 times and couldn't find anything wrong with it. I went North for the weekend, had about 500 or so miles on a brand new air cleaner and it sucked up a bunch again.
Went to Northwoods HD in Arbor Vitae, Wi to get a new filter to get me home and asked if they would install it (no tools) they said np and brought it in. Took a look and said needed to be looked at went in about 11 ish on Saturday by 4 they had installed new umbrella valve, fixed the leaky rocker boxes and install a new rear rotor total cost 111.00. Thanks Barb! This is what it looked like in early July
Don't think I will go back to the other shop anymore this is not the first time I had to go over 500 miles and have something fixed that they couldn't find..
lonerider is offline
post #2 of 3 (permalink) Old 08-21-2014, 06:24 PM
FrankieB's Avatar
vent the heads to the ground or a catch can and you won't loose another A/C
06 RK
11 RGU
FrankieB is offline
post #3 of 3 (permalink) Old 08-21-2014, 06:25 PM
tdkkart's Avatar
It's pumping that much oil, plus it has a leaky valve cover gasket??
Me thinks there's a drain-back issue somewhere that's causing the valve covers/top of the heads to become flooded with with oil.
tdkkart is offline
Oil Blow by at Air Cleaner Highway Troubleshooting for Road Glides 39 11-05-2017 11:33 AM
Oil From Air Cleaner Schmaxx Intake and Exhaust 6 09-19-2013 10:49 AM
Oil misting out my air cleaner....... jjyoung *General Road Glide Discussions/Pictures 7 09-08-2011 11:45 AM
Oil from SE air cleaner? dspencer Road Glide Specific Discussions 10 07-19-2011 01:00 PM
Oil coming out of SE Air Cleaner CSM11 Troubleshooting for Road Glides 10 07-04-2011 08:20 AM
