Need help removing bent fork tubes from tree - Road Glide Forums
post #1 of 7 (permalink) Old 09-01-2014, 06:41 PM Thread Starter
dvanlue's Avatar
I've started tearing down the front end of my wrecked 08 RG and hit a major snag. I know next to nothing but I have a service manual, u tube, this awesome forum, and I regularly stay at Holiday Inn Express. I'm hoping all of you gurus can give me some advise. I had a direct front impact that drove my fender back into the frame. Trashed the fender and rim, and appears to have tweaked the fork tubes and maybe the triple tree. I think the frame is okay but is has a small dent in the cross brace between the down tubes from the fender pushing the brake cable into it. I've taken out the pinch bolts and the top bolts but the tubes are tight as can be in the lower tree. I've driven them down from the top about 3/4" with brute force. They are just clear of the top tree bracket but still really tight. I've also tried to pry open the slot where the pinch bolt goes with a screw driver. I'm out of ideas except to continue to pound the hell out of it but I don't want to damage anything else. Any suggestions would be much appreciated. THX
2008 FLTR Candy Red Sunglo, S&S106, S&S push rods, Dragos 580 cams, Stage 2.5 heads, ported throttle body, Power Vision, Fuel Moto A/C, Aim lock up clutch, Dragos true duals, HogPro 21/18 Apollos, Ness hot legs, Native Customs cow bells.
2015 FLTRUSE Two tone blue.
dvanlue is offline
post #2 of 7 (permalink) Old 09-01-2014, 06:46 PM
torqu's Avatar
If you think the trees are bent, I would just separate the upper triple tree. Loosen and remove the caps for the forks, loosen pinch bolts, loosen steering neck stem, and try to pull the whole fork assembly down if you can. I've gotta set of triple trees off of my 2013 Fltrx if you need a set. 2200 miles on them.
torqu is offline
post #3 of 7 (permalink) Old 09-02-2014, 10:13 AM
Chances are the top tree is good and the front fork tube are deformed and hanging up in the lower tree.
Pull the speedometer/tach bezel and then take off the lower tree stem nut and both fork tube and the lower tree will come out as a unit.
once the lower tree is out you can take a right angle grinder with a cutting wheel and cut the tubes above and below the lower tree and then remove the remaining tube that is still in the tree.
If the lower tree is tweaked then forget about getting the old tubes out and just put in a new lower tree.
post #4 of 7 (permalink) Old 09-02-2014, 03:09 PM
FrankieB's Avatar
If the tubes are bent, just cut them off. Stock spring are cheap or even free if ask the forum real nice.
06 RK
11 RGU
FrankieB is offline
post #5 of 7 (permalink) Old 09-02-2014, 05:41 PM
Got a set of stock springs, cans and lowers with 5 miles on them. Yours for just shipping. PM me if you want them.
DuraGlide is offline
post #6 of 7 (permalink) Old 09-02-2014, 09:20 PM
rageglide's Avatar
I presume you've stripped them down to individual legs... If not, remove the axle at least.
If they are so badly bent that an individual tube can't slide out the bottom tree, I'd be replacing the lower tree without hesitation and I would also take the frame to a frame shop to check the neck.
2012 fltrx
rageglide is offline
post #7 of 7 (permalink) Old 09-02-2014, 09:49 PM Thread Starter
dvanlue's Avatar
Thanks for the help guys. I pulled the lowers and top tree and I'm going to pull the monotubes to see if they are okay. The Ness lowers look fine. Going to trash the tree and tubes and get a raked tree and go 23" on the front since I need a new rim anyway. Will also check out the frame.
dvanlue is offline
Need fork tubes 09-up touring CHROMESMUGGLER Wanted! (Buy or Trade) 6 11-28-2016 01:54 AM
Removing forks from Tree's Z-SHARK Suspensions 9 07-22-2014 08:34 PM
Help with fork tubes Footz Suspensions 1 07-11-2012 03:55 AM
Bent stanchion tubes 07 RG hardcandy Suspensions 4 07-05-2012 09:37 PM
fork tubes wanted locokk64 Wanted! (Buy or Trade) 1 04-12-2012 12:13 AM
