P&A Ignition Fuse? - Road Glide Forums
post #1 of 4 (permalink) Old 04-09-2012, 05:38 PM Thread Starter
Nickster's Avatar
P&A Ignition Fuse?
Anyone know what the P&A Ignition fuse is for in the fuse box of a 2012 RGU?
The fuse scematic states max. 2A fuse but mine has a 15A in there. That's how I picked it up from the dealer.
Nickster is offline
post #2 of 4 (permalink) Old 04-09-2012, 07:59 PM
EdY39's Avatar
I'm assuming that P&A probably means "parts & accessory". Size of the fuse will depend on what you're hooking to the P&A connection. Maybe someone was gonna hook up heated gear????
Ed
2002 RoadGlide
DPCM, USN (Retired)
EdY39 is offline
post #3 of 4 (permalink) Old 04-09-2012, 11:29 PM
Triplej's Avatar
There are actually 2 separate P&A fuses. One is rated for 15Amps and the other for 2 Amps. The 15amp is powered on the Accy. and Ignition side while the 2 Amp is powered only on the Ignition side.
Maybe these pics will help.
Triplej is offline
post #4 of 4 (permalink) Old 04-10-2012, 05:30 PM Thread Starter
Nickster's Avatar
Thanks Triplej for taking the time to snap the photos. This helps explain everything.
Nickster is offline
P & B fuse blows chevelledude Troubleshooting for Road Glides 6 01-06-2015 09:19 PM
2007 RG keeps blowing 15A ignition fuse fxdlrider Troubleshooting for Road Glides 0 08-18-2014 06:53 PM
Blowing in line fuse Hawg Wire Amp ?? redbaron Audio 3 04-06-2014 12:18 PM
blowing ignition fuse drmudd Troubleshooting for Road Glides 4 07-31-2012 06:02 PM
40 amp main fuse twowheel99 Do-IT-Yourself 4 03-05-2011 06:55 PM
