symptoms of a failing compensator - Road Glide Forums
post #1 of 17 (permalink) Old 09-16-2014, 12:20 AM Thread Starter
Boogitybob's Avatar
What are symptoms of a bad compensator ? What exactly happens when one fails ?
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
post #2 of 17 (permalink) Old 09-16-2014, 07:34 AM
You'll start getting a bang or clunking noise from the primary when starting and or shutting the bike off. It start alil harder
post #3 of 17 (permalink) Old 09-16-2014, 08:31 AM
A bing , a bang , a boom. Also look for excess metal particles in the primary oil.
post #4 of 17 (permalink) Old 09-16-2014, 09:49 AM
As mentioned the CLUNK is a common sign but hard starting is the sign it is getting real bad.
When starting the bike it will sound as if you have starter problems and you will get starter skip, grind and stall and the symptoms are worst when starting the bike with a hot engine.
post #5 of 17 (permalink) Old 09-16-2014, 11:20 AM
Sounds like it(like it's goona take your left leg off), seems you can prolong a teardown by starting in N and not restricting A/C, no shavins yet and since begin of summer always a com'on baby when firein-up then exhale as she rumbles, 03>95k
reds4 is offline
post #6 of 17 (permalink) Old 09-16-2014, 11:44 AM
MYFLTRX's Avatar
Hmm, since day 1!!! I had it "re-torqued" under warranty many miles ago.
MYFLTRX is offline
post #7 of 17 (permalink) Old 09-16-2014, 12:18 PM
Bull_Duck's Avatar
So far, none of the sounds attributable to failing compensator have been emitted from my '08.
Do some upgrade to the SE 40274-08A simply as a precaution. If so then perhaps I need to put the compensator upgrade on my winter rebuild list.
Bull_Duck is offline
post #8 of 17 (permalink) Old 09-16-2014, 04:09 PM
Hullhorr's Avatar
If you are not having any problems I would leave well enough alone. The problem with the SE Compensator is a lack of lubrication because of the design. The newest design addresses this issue somewhat, but time will tell if it really fixes it.
2009 FLTR MOP
Hullhorr is offline
post #9 of 17 (permalink) Old 09-17-2014, 06:35 PM Thread Starter
Boogitybob's Avatar
I'm getting lot of noise from lower left side on startup Goes away after 2-3 min I did notice some fine metal on drain plug but nothing excessive. I suspect compensator going south. A month out of warranty just my luck
BoogityBob
post #10 of 17 (permalink) Old 09-18-2014, 08:26 AM
Shrug's Avatar
Hmmm...I sometimes get a knock upon ignition, but it's happened since day one and hasn't worsened. Hester is a 2010, which I understand was a banner year for compensator failures.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
Multiple symptoms, single culprit? Ranger75 Troubleshooting for Road Glides 15 06-07-2014 10:43 AM
What does a failing compensator look like thedrill Engine Related 19 01-27-2014 10:00 PM
Failing Schools scayne62 General Off-Topic Discussions 19 01-11-2013 10:42 AM
Remember the symptoms..... nondairycreamer General Off-Topic Discussions 8 09-21-2011 05:37 PM
Loss of Mileage, engine seems to be 'seeking' an RPM, Cruise is failing Timinfla2 Troubleshooting for Road Glides 18 04-26-2011 04:08 PM
