front fork oil - Road Glide Forums
post #1 of 10 (permalink) Old 10-20-2014, 03:52 PM Thread Starter
front fork oil
bike coming up on 50,000 manual says change fork oil what do most put back in and how hard is the job to drain and get the oil back in. Thanks
easttnrhino is offline
post #2 of 10 (permalink) Old 11-14-2014, 10:57 AM
FireGuy88's Avatar
Bump*
I'm also interested in this as I plan to drop in Ricor's Intimnators this winter.
FireGuy88 is offline
post #3 of 10 (permalink) Old 11-14-2014, 12:32 PM
FrankieB's Avatar
If the ride is good for you just put the stock weight back in it. Personally i would pull the forks off and check the wear items while you are at it. Plus you can turn them upside down in a drain pan over night to get all the old oil out.
06 RK
11 RGU
FrankieB is offline
post #4 of 10 (permalink) Old 11-14-2014, 02:38 PM
JacktheBagger's Avatar
SE heavy weight I think it's called ,, is 10 or 15w
stiffens it up a bit , no nose diving
JtB
2011 Ultra
JacktheBagger is online now
post #5 of 10 (permalink) Old 11-14-2014, 06:15 PM
What Frankie said but if you just want to drain and fill , use a cup to measure what you take out. You may need heat to remove the drain screws. A lot of guy use the HD SE fork oil to reduce the bounce of the stock front end.
Big_gary is online now
post #6 of 10 (permalink) Old 11-14-2014, 08:33 PM
NorCal's Avatar
Originally Posted by FireGuy88 View Post
Bump*
I went this route and am pleased, no nose dive. Also on the advice from Ricor I also installed Race Tech Springs (FRSP S3234100) at the same time. Very simple job.
NorCal is offline
post #7 of 10 (permalink) Old 11-14-2014, 11:33 PM
moose1's Avatar
I changed mine out after I bought it for 30wt fork oil it will stiffen them right up
2012 FLTRU vivid black
moose1 is offline
post #8 of 10 (permalink) Old 11-15-2014, 12:07 AM
The Volusianator's Avatar
Tagged
The Volusianator is offline
post #9 of 10 (permalink) Old 11-15-2014, 11:32 AM
skratch's Avatar
isn't 30 wt fork oil about the same as concrete? i believe that that is even heavier than the se race (which is not recommended for the street)
skratch is offline
post #10 of 10 (permalink) Old 11-17-2014, 05:47 AM
moose1's Avatar
Its a big improvement over the 10wt I don't know about not using it in street bikes I didn't see anything on the label I'll have check it out I'm planning on installing mono tubes this winter anyway
moose1 is offline
Ultra front fork oil volume craigp95 Suspensions 5 06-09-2015 09:02 AM
Fork oil 2014 street glide with 49 mm front legs JPROADGLIDE Fluids and Lubricants 2 11-21-2014 12:37 PM
Front fork oil newbie issues Road08Glide Suspensions 36 08-09-2013 08:36 PM
Front fork oil leak DWyellowRG Suspensions 1 05-30-2013 08:43 PM
Front end dive and fork oil 96349 *General Road Glide Discussions/Pictures 5 05-19-2010 04:38 AM
