Turn signal removal - Road Glide Forums
post #1 of 8 (permalink) Old 11-30-2014, 03:36 PM Thread Starter
MASQUEDMANN's Avatar
Turn signal removal
I'm in the process of blacking out all the chrome. Do I need to remove the fairing to get the front turn signals off. I already have the bolts out just need to disconnect the wires
Tia
Masque
MASQUEDMANN is offline
post #2 of 8 (permalink) Old 11-30-2014, 04:01 PM
Warpath 41's Avatar
Yes just unscrew the 6 torx screws in the fairing. Outer lifts right off. The connectors for the t/s are secured to the inner fairing
[SIGPIC[/SIGPIC]2013 Candy Orange RGC-Power Vison Tuner, De-Catted Head Pipe, Jackpot 4" Slip-Ons, Fuel Moto Billet A/C, Wild 1 502 Chubby's, Painted Inner, Color Matched Vented Lowers w/Boom Speakers, 12" Windvest..........
Warpath 41 is offline
post #3 of 8 (permalink) Old 11-30-2014, 04:06 PM Thread Starter
Thanks Warpath. Was hoping I didn't have to remove the fairing. looks like a pia. I'll deal with that in the begining of spring when I get new bars. Thanks again for the response
post #4 of 8 (permalink) Old 11-30-2014, 08:05 PM
Paul's Road Glide's Avatar
You do not need to take off the fairing. Just loosen the four nuts holding the turn signal and pull the wire down and out a little bit. That's exactly how I did it.
Paul's Road Glide is offline
post #5 of 8 (permalink) Old 12-01-2014, 08:44 AM Thread Starter
Will try that Paul thanks
post #6 of 8 (permalink) Old 12-01-2014, 09:39 AM
DED HD's Avatar
Shouldnt have to, but its good practice to try and take outer off and re-install. But you can just pull enough on them so you can disconnect the wire connector.
'10 Red Custom:
DED HD is offline
post #7 of 8 (permalink) Old 12-01-2014, 10:28 AM Thread Starter
Yea DED gonna get that practice in the spring usually the bike is tucked away already. Just taking advantage of the warmer days to get some work done
post #8 of 8 (permalink) Old 12-01-2014, 05:35 PM Thread Starter
Got it off by pulling the wiring out
Turn Signal removal & Breakdown for Powder Coat tlar1540 Lighting 6 02-15-2016 08:41 AM
Kuryakyn front turn signal locate harness kimmer127 Lighting 2 12-06-2011 01:45 AM
turn signal covers rdbateman Lighting 9 07-24-2011 10:49 PM
run-brake-turn signal module ATrain Lighting 18 02-02-2011 11:37 PM
Rear Turn signal light bar sportyguy69 Lighting 2 08-21-2010 04:44 PM
