Shift linkage removal - Road Glide Forums
post #1 of 13 (permalink) Old 11-30-2014, 03:44 PM Thread Starter
MASQUEDMANN's Avatar
In the process of blacking out all the chrome. How do I remove the shift linkage and the perches if that's what they are called. Pic below with red line pointing to what I'm referring to
Tia
Masque
MASQUEDMANN is offline
post #2 of 13 (permalink) Old 11-30-2014, 04:01 PM
You will have to remove the inner primary to get the rear shift lever off. It's on a splined shaft with an allen bolt that has to be removed but in order to remove the lever you need to slide it off the shaft and there's no room with the inner primary in place
rlaf75 is online now
post #3 of 13 (permalink) Old 11-30-2014, 04:09 PM Thread Starter
Thanks rlaf75, sounds a bit complicated. I'll be removing the primary cover to get powder coated I'll see then if it's something I can tackle. If not it stays chrome to give the bike some contrast lol
post #4 of 13 (permalink) Old 11-30-2014, 04:34 PM
Once the outer is off you'll need to take the compensator sprocket, chain and clutch basket off. Then there's a gasket between the crankcase and inner and the inner primary seal on the inner primary and five bolts with o-ring washers that should get replaced too. It believe it or not isn't a bad job but can get alil pricey even doing it yourself. You may just want to tape everything off real good and rattle can spray it if it bothers you that much
post #5 of 13 (permalink) Old 11-30-2014, 05:19 PM
Do yourself a favor & invest in a HD Service Manual.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #6 of 13 (permalink) Old 11-30-2014, 05:28 PM Thread Starter
Thanks for the info rlaf75
post #7 of 13 (permalink) Old 11-30-2014, 05:29 PM Thread Starter
Hillglide one is on its way
post #8 of 13 (permalink) Old 11-30-2014, 06:34 PM
TRUBlue's Avatar
A lot of replacement linkages come with a cover for the rear lever. You could just do the cover without taking the inner primary off. It's part number 1 on this diagram.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #9 of 13 (permalink) Old 11-30-2014, 07:58 PM
moose1's Avatar
It will come right off without taking anything off. Just loosen the Allen head bolt and slide it off you might have to use a screwdriver to help. I know this cuz mine fell off the other day when I was in Dallas luckily it was still attached in the front and trust me it's no fun putting it back on when your on the side of the highway
2012 FLTRU vivid black
moose1 is offline
post #10 of 13 (permalink) Old 11-30-2014, 08:12 PM
There can't be much room to slide on and off. At least it doesn't look like there's much room
Shift linkage problem FLTRIder Troubleshooting for Road Glides 24 07-17-2015 08:35 AM
Quick and easy shift linkage mod skratch *General Road Glide Discussions/Pictures 52 02-18-2014 05:44 PM
Black Billet Flame Shift Linkage wachuko Aftermarket Accessories 19 05-02-2011 10:36 PM
Customized shift linkage ybnorml *General Road Glide Discussions/Pictures 19 03-14-2011 07:22 AM
Billet shift linkage blacktopr Aftermarket Accessories 0 03-26-2010 02:30 PM
