Rear brake assembly removal - Road Glide Forums
post #1 of 18 (permalink) Old 12-01-2014, 03:20 PM Thread Starter
MASQUEDMANN's Avatar
Rear brake light assembly removal
Trying to remove the rear brake assembly having a pia time can anyone tell me how to get this thing off.
No idea why the pic is upside down
TIA
Masque
MASQUEDMANN is offline
post #2 of 18 (permalink) Old 12-01-2014, 03:23 PM
torqu's Avatar
What are you trying to remove??? The rear brake assembly is held on by the rear axle shaft. Or are you removing the rear brake light assembly?
torqu is offline
post #3 of 18 (permalink) Old 12-01-2014, 03:25 PM
You mean the lights? There are two bolts positioned under the fender just inward of the lights that hold the assembly on. What are you trying to change?
post #4 of 18 (permalink) Old 12-01-2014, 03:39 PM Thread Starter
Sorry meant lights
post #5 of 18 (permalink) Old 12-01-2014, 03:40 PM Thread Starter
Removed the bolts can't find where to disconnect the wiring. Removing the lights assembly to powder coat
post #6 of 18 (permalink) Old 12-01-2014, 03:41 PM Thread Starter
Got the bolts off already need to disconnect the wiring
post #7 of 18 (permalink) Old 12-01-2014, 04:11 PM
If I remember correctly, they're plugged into the bottom light on the fender.
post #8 of 18 (permalink) Old 12-01-2014, 04:31 PM
DED HD's Avatar
i think they plug into the tri-bar light. One plug on each side.
'10 Red Custom:
DED HD is offline
post #9 of 18 (permalink) Old 12-01-2014, 05:33 PM Thread Starter
I saw that the wires went into both sides. It's so tight couldn't see the plug to unplug it. I'll try again tomorrow
post #10 of 18 (permalink) Old 12-01-2014, 07:46 PM
Ohiobellboy's Avatar
You are correct.
IIRC, the right side or throttle side of the bike is where the pigtail goes into those lights.
A.K.A OBB
Ohiobellboy is online now
Rear brake pedal removal ACESnEIGHTS Do-IT-Yourself 8 08-23-2015 03:43 AM
Head light assembly removal Magnum *General Road Glide Discussions/Pictures 9 04-01-2014 06:57 PM
Headlight assembly removal? justincollins *General Road Glide Discussions/Pictures 5 02-08-2013 11:08 PM
Headlight Assembly Removal Kerryebro Lighting 6 06-15-2012 08:36 AM
Changed rear brake arm now almost no rear brake? ncbeast Troubleshooting for Road Glides 4 05-30-2011 09:13 PM
