Outer primary, Tranny and Cam cover removal?? - Road Glide Forums
post #1 of 10 (permalink) Old 12-02-2014, 01:53 PM Thread Starter
MASQUEDMANN's Avatar
I'm removing the outer primary tranny and cam cover to get powder coated is there any danger in leaving these covers off. A friend said to spray them all with wd40 then cover with rags, right now they are taped up with plastic covering.
bike is in a non heated garage i had planned on leaving the covers off till spring, if that's not a good idea please let me know ill rush the powder coating and re install asap.
Tia
Masque
MASQUEDMANN is offline
post #2 of 10 (permalink) Old 12-02-2014, 02:45 PM
calgaryglide's Avatar
I would cover them with some shrink wrap type of packaging, like what they use to wrap pallets of goods for shipment. Something just to keep the dust out while you wait and keep the oil that could drip out from the cam chest and clutch side contained. Something is better than nothing.
When I changed my cams out last winter I used some cleaning rags draped over the cam chest to keep dust out and a drip pan underneath to catch the oil.
Calgaryglide
2019 FLTRU, Tyggr
calgaryglide is offline
post #3 of 10 (permalink) Old 12-02-2014, 03:04 PM Thread Starter
thanks right now all i have are some kitchen garbage bags taped over them ill try to get some shrink wrap.
what about moisture should i be worried about that since the garage isnt heated?
post #4 of 10 (permalink) Old 12-02-2014, 03:08 PM
I think if you try to seal everything as tight as you can even with the kitchen garbage bags there should not be a problem with moisture. If the garage were heated and you were in and out of it all the time with a wet car or water laying on the floor with everything exposed you might get some rusting then. Everything that is exposed should have a good coat of oil on it already. It will be in the cast at a molecular level, believe me, the oil gets in there.
Keep it sealed as best you can until you are ready to put it all back together.
Calgaryglide
2019 FLTRU, Tyggr
post #5 of 10 (permalink) Old 12-02-2014, 03:10 PM Thread Starter
Thanks for advice and info. Will do
post #6 of 10 (permalink) Old 12-09-2014, 05:19 PM Thread Starter
Primary, Cam, Clutch and tranny top cover off. I have it all covered with saran wrap. Everything has a good coating of oil. The garage is not heated will I be ok to leave it like that all winter or should I put those pieces back on as soon as I get them back?
post #7 of 10 (permalink) Old 12-09-2014, 06:04 PM Thread Starter
Should I put some of this stuff in the garage
post #8 of 10 (permalink) Old 12-09-2014, 07:07 PM
Jetman's Avatar
It won't hurt, but really not needed. Once you put everything back on, your gonna put in fresh fluids anyhow, so I wouldn't fret too much about it.....
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #9 of 10 (permalink) Old 12-09-2014, 07:57 PM
RoadGlideGary's Avatar
Just cover to keep the dust/dirt/wind-blown trash out. For sure you will want to replace fluids .
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #10 of 10 (permalink) Old 12-09-2014, 08:07 PM Thread Starter
Definitely new fluids at the beginning of every season. Thanks for the info
Chrome Primary Cover, Rocker Boxes, Cam Cover, Transmission Side and Top Covers, merritta Parts for Sale 1 04-20-2018 04:03 PM
2009 Chrome Outer Primary and Derby Cover METIME Parts for Sale 3 06-11-2013 11:49 AM
Chrome Outer Primary Cover Harley 60506-99 Shrug Parts for Sale 0 05-24-2013 08:25 PM
2008 Outer Primary Cover Corrupted Parts for Sale 1 05-07-2013 07:41 AM
Dash w/ gas door, rear mc chrome cover, & outer primary Swagzilla Parts for Sale 1 01-11-2013 09:55 AM
