Priming After Oil Change - Road Glide Forums
post #1 of 13 (permalink) Old 05-27-2012, 11:43 AM Thread Starter
MakeARunMike's Avatar
Does anybody have a good way of priming the oil system after an oil change? Whenever I do it I have to do a start/kill start/kill until i think the oil pressure is back up and where it should be. I thought about taking the plug wires off and just turning the engine over. Any tips?
Just lookin' for a little more chrome and a little more rumble...
10" Monkey Bars
ThunderMax ECM
Arlen Ness Big Sucker
Vance & Hines Dresser Duals
Klock Werks SS Slash Up
4-Speaker Set Up w/ Amp
Chopped Tour Pak
Other Chrome Doo Dads
MakeARunMike is offline
post #2 of 13 (permalink) Old 05-27-2012, 12:30 PM
tmd
Priming is not necessary. Just start the engine and let it idle, the oil pressure will go back to normal in just a few seconds. Its no different than changing the oil in a car engine and starting it afterwards. You would be surprised at how long an engine can run at idle with no oil pressue and not sustain any damage.
tmd is offline
post #3 of 13 (permalink) Old 05-27-2012, 01:06 PM
Radioactive's Avatar
+1, don't need to prime it!!!
Radioactive is offline
post #4 of 13 (permalink) Old 05-27-2012, 01:14 PM
avidcycler's Avatar
The method I use is to add oil to the new filter before installing it. This method is not in my HD manual but it is in my Buell Cyclone manual. I know the engines are quite different but the idea should apply to both... when the oil pump starts to pressurize the system the filter will already have a supply of oil to send out into the engine passages. I also use this method when changing oil in my cars.
avidcycler is offline
post #5 of 13 (permalink) Old 05-28-2012, 06:54 PM
TLWiz's Avatar
I have a beer. That has worked well for many years.
TLWiz is offline
post #6 of 13 (permalink) Old 05-28-2012, 07:09 PM
^Ding Ding Ding! We have a winner!!!
Dfwhockey17 is offline
post #7 of 13 (permalink) Old 05-29-2012, 08:38 AM
Just spin on the filter and fill engine with oil and start the engine, beer is optional but recommended. Putting oil in the filter can result in a oily mess. Also you should wash the oil off the front motor mount the oil has a tendency to ruin the rubber on the mount resulting in motor mount failure.
post #8 of 13 (permalink) Old 05-29-2012, 03:36 PM
avidcycler's Avatar
You don't need to put a whole lot of oil in the filter... my Buell Cyclone manual states: add 4.0 oz of oil to filter and screw filter onto filter housing.
As far as making an oily mess on the front motor mount, read HD_SHOCK's write up in this area under: "No mess oil filter change." I use this method almost to a "t", and it has worked for me... never had to wipe up any oil yet!
post #9 of 13 (permalink) Old 05-29-2012, 05:38 PM
We always add oil to the filter before re-installing, always. It is easy to do and doesn't really take more time to do with the guns we have....
post #10 of 13 (permalink) Old 05-29-2012, 07:18 PM
Bazinga's Avatar
like others have said. Fill the holes and start the bike. No need to prime the filter.
Bazinga punk! Now we're even!
Bazinga is offline
Lifters: to change or not to change BigNorm Engine Related 14 01-19-2016 08:50 AM
Front fender damage after fork oil change hoosierboarder Suspensions 15 08-01-2015 09:04 AM
Bike feels sluggish after oil change HELP TYM2GLIDE Engine Related 16 03-16-2015 06:47 PM
Clunking after Fork oil change Road08Glide Suspensions 2 05-13-2013 08:55 AM
What to do with oil change oil? TearlessTom *General Road Glide Discussions/Pictures 15 11-22-2011 09:16 PM
