Replacing brake fluid - Road Glide Forums
post #1 of 8 (permalink) Old 01-09-2015, 12:09 AM Thread Starter
Boogitybob's Avatar
Is it possible to replace brake fluid on an abs bike yourself ? On other bikes I would add fresh fluid while slowly draining at petcock as to not let air in.
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
post #2 of 8 (permalink) Old 01-09-2015, 12:18 AM
Some people say they have bleed their abs brakes without any problems. Since you're basically flushing the entire system then I'd suggest bringing it to the dealer so they can hook up to the computer and bleed them properly
post #3 of 8 (permalink) Old 01-09-2015, 07:39 AM
fltru103's Avatar
I wanted mine flushed as preventative maintenance, but the indie mechanic I use said he can't do it without the tool the dealer has.
Right now, if you have ABS, you don't have any choice other to go to the dealer for that service.
in my garage now...
2007 Dyna Screamin Eagle ... SOLD !
2011 RGU Merlot SunGlo
fltru103 is offline
post #4 of 8 (permalink) Old 01-12-2015, 10:19 AM
Wood's Avatar
I flushed my ABS system by myself without a problem. As noted earlier, some people who do it at home have problems, luck of the draw.
Wood is offline
post #5 of 8 (permalink) Old 01-12-2015, 10:38 AM
You should be able to gravity bleed the front but a vacum brake bleeder is the best for the rear.
post #6 of 8 (permalink) Old 04-11-2015, 09:16 PM
DanHappy's Avatar
Could you reverse bleed the front?
DanHappy is offline
post #7 of 8 (permalink) Old 04-13-2015, 04:43 AM
Phantom6722's Avatar
I've done my ABS brakes without any issues; I used a mighty-vac bleed pump to pull the new brake fluid through the systems.
I can do my clutch and both F/R brakes with a bottle of fluid (still leaves plenty for flushing). If you are going to do your brakes make sure you put a small piece of cardboard in between the front brake lever and the master cylinder housing so you do not damage the brake light switch when re-assembling.
Cheers Skip
Phantom6722 is offline
post #8 of 8 (permalink) Old 05-10-2015, 03:32 PM
+1..I used the same pump and had no issues. Take your time and check out YouTube. Couple of videos from people showing the steps.
Minivend is offline
DOT 4 to DOT 5 Brake Fluid Q-Hog Fluids and Lubricants 20 09-26-2015 01:03 PM
2011 RGU with ABS - Brake Fluid Change Minivend Do-IT-Yourself 11 08-15-2015 05:16 PM
leaking brake fluid THEMASTERDESTROYER Fluids and Lubricants 16 04-11-2014 09:05 PM
Brake Fluid Leak lldsilver41 Tech Area 2 09-10-2012 02:28 PM
How often do you flush your brake fluid? jcanrun *General Road Glide Discussions/Pictures 12 05-08-2011 01:28 PM
