Dielectric grease - Road Glide Forums
post #1 of 13 (permalink) Old 01-28-2015, 10:15 AM Thread Starter
sfcusaret2004's Avatar
Dielectric grease
While searching for a controller for my stage one set up I came across this informative article for the ever ubiquitous dielectric grease and its proper use,
https://www.youtube.com/watch?v=-542...ature=youtu.be
Having gone overboard on "sealing" my connectors when I first bought my bike. I inadvertently killed it, or so I thought. I had filled every connector I could find with this stuff, thinking I was sealing out moisture but in fact, I had increased the electrical resistance throughout the system so much, that the ECM could not get proper readings and it shut down the bike! When I took it to the dealer to figure out why the electrical system wasn't working, they hooked it their analyser and the electrical numbers were all over the place. When the figured out what was happening, they cleaned all of the grease out of the connectors (with contact cleaner) and reconnected everything. They then explained that most of the connections now days are sealed against moisture so the grease is not necessary. Like most folks, I thought you could use this stuff on every connection and didn't give any thought on how to use it. I figured if a little was good, more would be better. And why not use it on the pins and connectors as well as the wire entering the connectors. This video explains why not! and it makes it perfectly clear just how to use it. So, keep using the grease, just make sure you use it correctly!
sfcusaret2004 is offline
post #2 of 13 (permalink) Old 01-28-2015, 10:49 AM
Thanks for posting this informative video. I was one who believed more was better. I'll be making some changes to my way of thinking.
2012Road GlideUltra-Vivid Black,Vance & Hines Two into One Pro Pipe,Screamin' Eagle Race Pro Tuner,Screamin' Eagle High Flow Air Filter,16" L.A. Choppers Apes,16" Klock Werks Windshield,Hogtunes Big Ultra RG Audio Upgrade Kit,"Tall Boy" Seat,Chrome Levers,Grips,TurnSignalVisors. Powdercoated Fork Lowers&Cowbells,Metzeler Marathon 888's,Gold Valve Cartridge Emulators,GloveCompartment, Saddlebag,Trunk and Lower Fairing Liners,Highway pegs, Legend Revo-A's,Hog Trough Cup Holders
kevinhd1690 is offline
post #3 of 13 (permalink) Old 01-28-2015, 11:19 AM Thread Starter
I hear ya Kevin, glad to help.
post #4 of 13 (permalink) Old 01-28-2015, 11:21 AM
Thanks for the info & video.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #5 of 13 (permalink) Old 01-28-2015, 03:08 PM
Nordic Berserker's Avatar
My stock signal bulbs had globs of it on. When installing my custom dynamics, instructions said to remove dielectric grease from socket prior to installing LEDs
Nordic Berserker is offline
post #6 of 13 (permalink) Old 01-28-2015, 03:51 PM
A lot of peeps here going to be out buying contact cleaner after reading this.
Big_gary is online now
post #7 of 13 (permalink) Old 01-28-2015, 05:04 PM Thread Starter
post #8 of 13 (permalink) Old 01-28-2015, 06:33 PM
Interesting. I never really knew the proper use for that stuff aside from spark plug boots.
I'm curious how you would apply it to other connectors on the bike, or if it's even necessary? I hear of people using it all the time and assumed you just glob that crap on everything.
2012 FLTRX
Sideways is offline
post #9 of 13 (permalink) Old 01-28-2015, 06:53 PM
perrykw's Avatar
Good video. Only place I have used it so far is the throttle body connector.
perrykw is offline
post #10 of 13 (permalink) Old 01-28-2015, 07:00 PM
598Malibu's Avatar
Thanks for the link.
2012 Big Blue Pearl FLTRU
72 Chevelle with Procharged 598
598Malibu is offline
Dielectric grease reficul Lighting 20 02-03-2013 09:22 AM
Steering head grease zerk? Mopar1 Troubleshooting for Road Glides 6 01-04-2012 07:43 PM
grease fitting for headbearing???? cestaro Tech Area 12 10-14-2011 03:52 AM
Grease Drips from the.......Pic Nevadasun *General Road Glide Discussions/Pictures 8 09-22-2011 11:37 PM
Grease smell after a long ride?? 2010 FLTRX Troubleshooting for Road Glides 3 05-16-2011 10:03 AM
