2015 trouble questions - Road Glide Forums
post #1 of 13 (permalink) Old 04-08-2015, 03:55 PM Thread Starter
Mickeyv's Avatar
I have a few question. To see if anyone else has had this happen on a 2015. Washed the bike and now it will not start in gear. Has to be n neutral now to start. 2nd .The gear numbers also went off for about 30 miles. They have now come back on. 3nd question. touch screen goes dark and I have to turn the bike off and back on. I love the touch screen radio and gps, that is why I upgraded. But I did worry about this kind of problem. Anyone?
Mickeyv is offline
post #2 of 13 (permalink) Old 04-08-2015, 04:02 PM
Did you hose high pressure water right at the controls and HU ? Maybe the water got onto the wiring. Rain don't come down high pressure like a hose can produce, just be more careful next time in those area's.
post #3 of 13 (permalink) Old 04-08-2015, 04:14 PM
HellInABucket's Avatar
Just a thought - I know there were some software updates, did you get them?
HellInABucket is offline
post #4 of 13 (permalink) Old 04-08-2015, 09:51 PM
Johndeere's Avatar
I have had all of the above happen. Your cruise will not work either with no gear indicator. I think it does have something to do with cleaning and water. Now the radio that is the great gremlins of the new Rushmore bikes. SG and RG owners alike are having this problem.
15 RGS ported and polished, big sucker, Manlly springs, 10.5 Pistons, ported throttle body, Dragula 2, 12in Apes, Drago's 580 cam and 21 17 Southern MC wheels. ?HP/?TQ
Johndeere is offline
post #5 of 13 (permalink) Old 04-08-2015, 10:23 PM
Add to the list of issues with the Infotainment system.....GPS map upgrades.
The most recent map available is dated 2013 Q2....at a cost of $149 -$159. The MOCO site Infotainment software upgrades don't have anything to do with the maps in the GPS. You must go to https://harley-davidson.naviextras.com/shop/portal
Pretty sad how they are taking top dollar, for a touring product that is outdated before it even hits the road. GPS systems and Touring kind of go hand-in-hand
2013 BMW K1600GTL
2011 FLHX
2015________ TBD
K1600FLHX is offline
post #6 of 13 (permalink) Old 04-09-2015, 08:54 AM
What does it have to do with ?
post #7 of 13 (permalink) Old 04-09-2015, 08:41 PM Thread Starter
Mickeyv's Avatar
No power wash just hand washed it. Going to tell the stealer when get it service. Still will not start in gear been over 100 miles. Thanks for all of the help
Mickeyv is offline
post #8 of 13 (permalink) Old 04-10-2015, 08:25 AM
Try working the clutch lever a few quick times a before you try to start in gear. My switch sticks once in a while.
post #9 of 13 (permalink) Old 04-13-2015, 05:43 AM
The 15s will not start while in gear. New safety feature.
CVOLEO is offline
post #10 of 13 (permalink) Old 04-17-2015, 12:40 AM
My 15X I know I have started it in gear even after washing, as for the gear indicator working... it only works while in gear clutch fully released, so this may be a clutch switch issue with your bike & a stealer should be able to monitor switches via computer like I can with the SERPT. Now for the touch screen, I have had the same issues! Factory setup leaves options open... I suggest turning off the adaptive display simply because it uses the clock not where you are located or daylight savings or a ambient light sensor to determine how much backlight you may need. I turned off the adaptive display settings because I either travel from dark/sunrise or sunset/dusk which left my display miserable to see almost all the time. P.s. if your running an O.E. wind shield be sure to do the update via thumb drive & website to your radio OMFG I can finally hear the radio w/o horrible distortion that I never had on my old 07 FLTR. Still not up to par but it was like I was deaf before the update. Best of luck!!!
justchillaxin1 is offline
2015-2016 RG Stereo and removal questions i_timmers Audio 16 03-23-2016 04:48 AM
Accessory switch questions 2015 RGS Keithw1961 Aftermarket Accessories 2 08-29-2015 04:09 PM
Upgrading to a 2015 FLTRXS: Plethora of questions and decisions. Rasconzo *General Road Glide Discussions/Pictures 14 04-06-2015 07:11 PM
2015 model Questions Jetman *General Road Glide Discussions/Pictures 7 01-27-2015 08:05 AM
2015 Road Glide questions? Biggy *General Road Glide Discussions/Pictures 35 11-21-2014 10:44 PM
