scorpion clutch issue - Road Glide Forums
post #1 of 26 (permalink) Old 04-17-2015, 09:00 AM Thread Starter
getrdone's Avatar
My 2012 RGU was slipping in 5th gear. So i had my local bike shop install the barnett scorpion clutch with medium springs. Solved the slipping in 5th but then started to squawk/slip in first gear. Went with heavy duty springs which solved the 1st gear issue but now its slipping in 5th gear again. Its been back to the shop 4 times for the issue. Either its slipping in 5th or 1st. Back and forth with this issue. Any ideas??
Life is good but God is Great!
getrdone is offline
post #2 of 26 (permalink) Old 04-17-2015, 09:13 AM
pat123's Avatar
I remember reading people having issues and the removed the 2 dampening springs and it fixed their problems. Have you called Barnett? Sounds like something isn't installed correctly. My scorpion makes the noise when taking off. If your slipping with the hd spring in you have a problem.
pat123 is offline
post #3 of 26 (permalink) Old 04-17-2015, 11:37 AM
What motor in your RGU?
HeatWave is offline
post #4 of 26 (permalink) Old 04-17-2015, 02:19 PM Thread Starter
getrdone's Avatar
103" Heads have been ported/polished, 574 Reaper cam, push rods, Heavy breather, Zippers autotune.
getrdone is offline
post #5 of 26 (permalink) Old 04-17-2015, 04:09 PM
FrankieB's Avatar
To me it sounds like the adjustment is off on the clutch, especially after you put the heavy springs in it. The adjuster screw could be seated to deep and the plates aren't making full contact.
06 RK
11 RGU
FrankieB is offline
post #6 of 26 (permalink) Old 04-17-2015, 04:39 PM Thread Starter
getrdone's Avatar
Thanks! You may be right,
getrdone is offline
post #7 of 26 (permalink) Old 04-17-2015, 05:58 PM
I've seen this issue with the only 2 Scorpions that I know directly of, no slip (124s) but the 1st gear squawk was terrible; both on the CVO Hydraulic Clutch, I know you have a cable which gives more latitude for adjustment. Both guys went round and round with the Indys involved, with different primary fluids, installation procedures, etc...(not the Indy's fault IMO, Barnett's supplied instructions were lacking). After seeing what these guys went through, IMO the best way to fix (if, after making sure the clutch being properly adjusted doesn't cure ~ I reread and see it's an either / or issue) get your Indy, yourself and Barnett on the phone at the same time, tell them what bike you have, what fluid, the install procedure used and see what Barnett has to say.
After Barnett sent these guys new components, and following Barnett's over the phone installation procedures to a "T", the squawk was reduced significantly but still squawks from time to time...
Or if Barnett can't fix, just installing the SE Heavy Duty Spring ($35.) to your stock clutch (might have to replace the OE plates if they are fried?) is plenty for your motor...
HeatWave is offline
post #8 of 26 (permalink) Old 04-17-2015, 06:37 PM
hook's Avatar
I've been thinking of installing that clutch next winter.
What primary fluid are you using?
2011 RGU
hook is offline
post #9 of 26 (permalink) Old 04-18-2015, 07:37 AM Thread Starter
getrdone's Avatar
Thanks bro! They have had barnett on the phone a couple of times, Tried different fluids.. ATF and such. Seems like were chasing it back and forth. Either slips in 5th or squawks in 1st. FRUSTRATING!
getrdone is offline
post #10 of 26 (permalink) Old 04-18-2015, 12:51 PM
'Bet your Indy is sharing in the Frustration too Spring is here and he's probably getting busy... and you need to ride...
Unless Barnett / your Indy can come up with a timely solution, reinstalling the OE Clutch (I'd put in new OE plates) and the SE Heavy Duty Spring, might be the way to go???
Post here and let us know what you find??
Good luck!!
HeatWave is offline
Barnett Scorpion Clutch - Install Question gbourdon Engine Related 0 05-30-2014 10:24 AM
Scorpion Helmet? HarleyArcher Helmets 7 07-08-2012 05:21 AM
Barnett Scorpion Clutch Ruggerbk Tech Area 0 02-24-2012 06:49 PM
scorpion helmets ROBNCIN Helmets 11 11-17-2011 01:42 PM
2 Scorpion EXO 200 3/4 helmets ChromeYellow67 Classifieds Archive (3 months old+) 6 11-17-2011 03:04 AM
