Mystery oil leak - Road Glide Forums
post #1 of 20 (permalink) Old 05-04-2015, 01:06 PM Thread Starter
Mystery oil leak
Today I had a chance to ride my bike for the first time since returning from Leesburg. When I backed the bike out of the garage, there was a puddle of oil on the floor. First thing I did was check my oil level, it's within range. I then started the bike, normal pressure, then did a quick 15 mile ride, parked the bike, no leak after an hour. I'm going to ride some more then let the bike sit again. Has anyone experienced anything like this or have a clue?
post #2 of 20 (permalink) Old 05-04-2015, 01:11 PM
Bleachey's Avatar
Any clue where it dripped from on the underside of the bike?
Bleachey is offline
post #3 of 20 (permalink) Old 05-04-2015, 01:29 PM Thread Starter
No, I looked under the bike and it's a little dirty and greasy, but nothing freshly wet or anything. I'm probably going to clean and degrease the underside of the bike and keep checking.
post #4 of 20 (permalink) Old 05-04-2015, 02:16 PM
Bleachey's Avatar
Best of luck, it can be frustrating. I always start by checking drain bolts and orings, especially if there has been a recent service done.
Bleachey is offline
post #5 of 20 (permalink) Old 05-04-2015, 02:39 PM
Nordic Berserker's Avatar
dbell, similar thing happened to me a couple of weeks ago shortly after I got my bike back from getting the 107. I saw a small puddle of oil, at first I thought maybe it was from my chopper because I move the bikes around and that bike sometimes leaves a mark. Then it happened again and I knew now it was the RG, I degreased it under and and all around filter area after that it didn't drip anymore. it was just residue from sloppy oil change done at the shop
Nordic Berserker is offline
post #6 of 20 (permalink) Old 05-04-2015, 04:09 PM Thread Starter
Well, I cleaned the bike up, let it get hot, shut it off and waited. Almost like waiting for water to boil, and very slowly, sure enough the drain plug is the culprit. I'm over 2k miles into this oil change and had planned on changing right before SW5 anyway. I must admit this is the first time I've had a drain plug o ring fail. Interesting that it would happen midway through an oil change. I've looked and you can see no oil anywhere else and just a drop at a time on the plug, I've probably leaked about 1/2 ounce in the last hour.
post #7 of 20 (permalink) Old 05-04-2015, 04:13 PM
Do you remember what vacinity of the engine the puddle was at ?
post #8 of 20 (permalink) Old 05-04-2015, 04:18 PM
That's an easy fix. Remember not to over tighten the plug.
post #9 of 20 (permalink) Old 05-04-2015, 04:26 PM
glad you found it and it was nothing major, I guess your doing an oil change earlier then planned
post #10 of 20 (permalink) Old 05-04-2015, 05:45 PM
Been in the (not needed) habit on my own bikes to stretch an inch and 1/2 of 1/4 Teflon tape against the threads on the oil and tranny plug plus the O-rings.
reds4 is offline
Another mystery oil leak???? RonC26 Engine Related 18 12-04-2015 03:38 PM
My 95's Oil Usage Mystery(sort of) hawk06Glide Engine Related 20 02-11-2015 11:54 AM
Oil Leak? Primary Leak? shutzund Troubleshooting for Road Glides 4 06-04-2013 07:55 PM
Mystery Oil Leak FireGuy88 Troubleshooting for Road Glides 5 05-03-2012 05:39 PM
That's one mystery solved 2010 FLTRX Intake and Exhaust 11 06-08-2010 08:35 PM
