Front brake upgrade help - Road Glide Forums
post #1 of 5 (permalink) Old 07-28-2012, 11:46 AM Thread Starter
LittleMoe's Avatar
OK boys and girls, i determined that the front rotors were warped so i figured while i was there doing the rotors, i would upgrade the whole front brake system.
I ordered new rotors from EBC, new brakes from Hawk performance, new rotor bolts, and SS front line kit from Goodridge.
These are my questions. Which fluid would you guys recommend, DOT 4 or 5?? I want to black out my calipers, is there a special paint for brake calipers??
Is there anything else i'm missing???
'06 FLTRI/Gel seat/Rheinhart exhaust/PCIII USB/Wind Vest 16" sheild/Progressive Monotubes/WAAAY too much chrome Willie G chrome... wanna trade for blacked out parts?
LittleMoe is offline
post #2 of 5 (permalink) Old 07-28-2012, 10:56 PM Thread Starter
LittleMoe's Avatar
No thoughts on which DOT fluid to use??
post #3 of 5 (permalink) Old 07-29-2012, 01:20 AM
Bandit's Avatar
I would stick with Dot 5. You can research the differences, but I honestly believe 5 is superior to 4.
2005 FLTR - 97" S&S Big Bore, Hillside Cycle Stage II Heads & Throttle Body Upgrades, S&S Rollers, Fueling Pump & Lifters, 570G Gear Drive, TTS, CFR's, Klock Werks Double Back, 104hp/106ftlbs. CB's Euro, PM Light Glide LED Kit, RC CZar Wheels
Bandit is offline
post #4 of 5 (permalink) Old 08-29-2012, 12:05 PM
Dot 5
The 5 has higher temp rating and won't ruin your paint! if 4 gets on paint you are screwed so use 5 Ben
Ben67zl1 is offline
post #5 of 5 (permalink) Old 08-29-2012, 01:13 PM
RoadGlideRider's Avatar
First, if you are putting something different from the Harley brakes, read the material given with the brakes you buy.
Use the fluid they recommend.
But, if you are using Harley Brembo Brakes, or they look like the Harley brakes,
I would stick with the fluid called for in the Harley Service manual, DOT4.
If something was to happen to your bike, and you take it into a dealer, they will assume that it is DOT4.
HD used DOT3/4 for years up until 1976, then switched to DOT 5. Then in mid-200's on SOME bikes
went back to DOT 4 and left others at DOT 5...Now all HD's are back to DOT4.
DOT5 has a higher boiling point but is a different type of fluid and attracts water more then DOT4.
DOT5 must be bleed often to maintain top performance.
DOT5 is basically a racing application, for full size cars or some race bikes.
I would stick with DOT4.
RoadGlideRider is offline
Brembo Brake upgrade Lacyvilla *General Road Glide Discussions/Pictures 4 09-25-2017 09:42 PM
Brake upgrade ideas glide5252 *General Road Glide Discussions/Pictures 3 06-01-2017 06:26 AM
Changed front tire now no front brake??? jrbean1 Troubleshooting for Road Glides 9 07-24-2014 11:05 PM
Front brake line replacement help MoRob Controls & Handlebars 3 04-04-2013 11:13 PM
LA Choppers extended front brake line help. mandlbarrett Controls & Handlebars 7 07-22-2012 09:52 PM
