Loose saddlebag - Road Glide Forums
post #1 of 10 (permalink) Old 05-16-2015, 06:54 AM Thread Starter
Loose saddlebag
I need help. I removed my left saddlebag yesterday to adjust suspension. After riding a few miles to test, i noticed my bag was loose. One of the quarter-turn pins had come out. I put it back in and rode home. Came out again. Any ideas on how to secure the pin? Thanks for any help.
Epsilonfall89 is offline
post #2 of 10 (permalink) Old 05-16-2015, 07:03 AM
OKBigD's Avatar
Ditch the pins and buy a set of these... https://www.roadglide.org/showthread....postid=2684049
OKBigD is offline
post #3 of 10 (permalink) Old 05-16-2015, 07:14 AM
100edition's Avatar
Agreed. Put a set on 3 weeks ago. Even got rid of some rattle noise.
100edition is offline
post #4 of 10 (permalink) Old 05-16-2015, 07:22 AM
staush's Avatar
bags
Did you lose the rubber washer? GO TO ACE HARDWARE FOR CLIP AND BOLT.
staush is offline
post #5 of 10 (permalink) Old 05-16-2015, 07:28 AM
JacktheBagger's Avatar
Don't have to buy anything , for the past thirty odd years I have run a bolt thru the bags with lock washers and nuts on the inside , no rattle , no theft , with stuff I have laying around the shop ..
JtB
2011 Ultra
JacktheBagger is offline
post #6 of 10 (permalink) Old 05-16-2015, 07:30 AM
mmfinn's Avatar
JtB
+1to that. The only way to go. Ditched my pins the day I got the bike.
mmfinn is offline
post #7 of 10 (permalink) Old 05-16-2015, 08:56 AM
Sometimes the slot in the pin will open up a little bit, you can just use a pair of pliers to pinch the end of the pin a little to close up the slot. Bolts are a good idea if you don't remove the saddlebags much but I still use the pins because I like to take off the saddlebags for cleaning & maintenance.
I do have the wrap around saddlebag guards so if the pins come out the saddlebags won't fall off the bike, If you don't have the guards then the bolts would be a better option.
post #8 of 10 (permalink) Old 05-16-2015, 10:17 AM
GlideShark's Avatar
Agreed, though you have to tighten them a bit every once in a while.
GlideShark is offline
post #9 of 10 (permalink) Old 05-16-2015, 12:13 PM
Between my last 3 baggers I have close to 100k miles on the stock pins and never had one fall out. Same style pins held the body panels on my drag cars that ran well over 100mph. YMMV
DuraGlide is offline
post #10 of 10 (permalink) Old 05-17-2015, 07:51 AM Thread Starter
Thanks everyone for advise. The rubber washers will be a definite to reduce the rattle. I appreciate you all.
Headlights loose NoBull Road Glide Specific Discussions 11 04-18-2011 08:43 PM
Possible loose triple tree bearings on 09 RG j schleifer Troubleshooting for Road Glides 3 01-28-2011 07:46 AM
Possible loose triple tree bearings j schleifer Troubleshooting for Road Glides 1 01-26-2011 05:58 PM
Never again loose a wellnut in your faring BDMastiff *General Road Glide Discussions/Pictures 9 10-05-2010 10:38 AM
2010 loose duel headlights bigtwin Lighting 6 04-25-2010 09:16 PM
