Oil Cooler - Road Glide Forums
post #1 of 9 (permalink) Old 08-06-2012, 07:33 AM Thread Starter
Oil Cooler
The oil cooler adaptor on my 2011 RG Ultra is leaking. Seems to be a common issue. My question is do I use a sealant on both sides of the gasket ? The one from HD has a peel off side with some sort of sticky. It's a PITA to change so I thought some of the more experienced guys could point me in the right dirrection. Thanks
vetteman is offline
post #2 of 9 (permalink) Old 08-06-2012, 08:35 AM
tmd
2 year unlimited milage warranty. Make the MoCo fix it on their dime.
tmd is offline
post #3 of 9 (permalink) Old 08-06-2012, 09:10 AM
TLWiz's Avatar
Are you out of warranty?
TLWiz is offline
post #4 of 9 (permalink) Old 08-06-2012, 09:11 AM Thread Starter
leak
Yea I thought about that. I would rather do it myself for something like this. They would require a appointment & probably keep it a couple of days.
vetteman is offline
post #5 of 9 (permalink) Old 08-06-2012, 09:12 AM Thread Starter
leak
No it is still under warranty.
vetteman is offline
post #6 of 9 (permalink) Old 08-06-2012, 10:06 AM
tmd
And if you take it apart and find that its something more then a basket or seal you hosed yourself.
tmd is offline
post #7 of 9 (permalink) Old 08-06-2012, 11:15 AM Thread Starter
[QUOTE=tmd;280492]And if you take it apart and find that its something more then a basket or seal you hosed yourself.[/QUOTe
Got it back together and no leaks.
vetteman is offline
post #8 of 9 (permalink) Old 08-06-2012, 02:15 PM
jupiter's Avatar
[QUOTE=vetteman;280511]
I just had the same issue on mine..noticed it on a saturday night before leaving on a long trip on Tuesday so had to fix it myself.
Where did you come up with the 7/16 or 11mm allen head wrench? I ended up double nutting a cap screw with that head size and using a socket on the nuts.
My adaptor was slightly loose and I did not have access to any gaskets. I got about a 1/8 -3/16 of a turn on it and it stopped leaking.
Priscilla- 11 RGU VB with FM intake, HP, DT mufflers and FM tune.
jupiter is offline
post #9 of 9 (permalink) Old 08-06-2012, 03:34 PM Thread Starter
[QUOTE=jupiter;280578]
My neighbor works on big trucks & he had one.
vetteman is offline
Oil Bud Oil Cooler easybiker Engine Related 10 07-22-2015 02:34 PM
Oil Bud Oil Cooler install 2013 RG ultra Big_Mo Aftermarket Accessories 0 08-09-2014 10:32 AM
Removing oil filter with oil cooler 02heritage *General Road Glide Discussions/Pictures 17 05-12-2014 12:10 AM
Jagg Oil Cooler turned to Oil Drooler! OldNerdGuy *General Road Glide Discussions/Pictures 6 07-22-2013 12:04 PM
Oil Cooler Tip doc Do-IT-Yourself 8 03-26-2010 03:19 AM
