To change or not..... - Road Glide Forums
post #1 of 13 (permalink) Old 06-03-2015, 04:37 PM Thread Starter
MShell's Avatar
Just looking for some opinions based on the pic of these brake pads on whether to change or not?
These are my original rear pads on a 2012 RGU.....OH AND 62,000 miles on it
Lug nut rule, the one with the most lug nuts wins
MShell is offline
post #2 of 13 (permalink) Old 06-03-2015, 04:44 PM
Triplej's Avatar
I am guessing you don't use the rear brake very often?
But the pads look fine.
Triplej is offline
post #3 of 13 (permalink) Old 06-03-2015, 05:10 PM
RGUrider's Avatar
Those were my exact thoughts when I viewed pix..I think I changed out my rear pads around 10K.
RGUrider is offline
post #4 of 13 (permalink) Old 06-03-2015, 06:40 PM
Might want to start using front & rear brakes to stop. jmo
Big_gary is online now
post #5 of 13 (permalink) Old 06-03-2015, 07:07 PM
exercise the lever, see if the caliber is operational, what's the rotor look like??
reds4 is offline
post #6 of 13 (permalink) Old 06-03-2015, 07:31 PM
Nordic Berserker's Avatar
wow how many times have you changed the front pads? just curious
Nordic Berserker is offline
post #7 of 13 (permalink) Old 06-03-2015, 09:58 PM Thread Starter
MShell's Avatar
I use front and rear, fronts look the same, some extensive on the job training so not a lot of brake use but, lots of down shifting.
MShell is offline
post #8 of 13 (permalink) Old 06-04-2015, 03:36 AM
Wood's Avatar
Very impressive being able to keep the same front and rear brake pads for 62K and to have them look almost new. I must assume you don't ride in the city much.
Wood is online now
post #9 of 13 (permalink) Old 06-04-2015, 09:21 AM
You must be coasting to a stop most of the time.
I use my back brakes all the time along with downshifting and I replace the pads every time I put on a new rear tire. I never use the front brakes when doing a controlled stop, I do use the front brakes when there is a need for extra stopping power.
That just the way I ride, other riders use the front brake more than the back. The good news is that your rear brake pads are just fine so you don't need to change them.
post #10 of 13 (permalink) Old 06-04-2015, 01:07 PM
2011 RGU with 17,000 miles. Just changed the front and rear using Lyndall pads. Bought the pads from HOGPRO. My front had some life left and my rear pads were almost new as I use my front brake 90% of the time. Took me 45 minutes to do the job and I had no issues. I'm going on a long cross country trip and figured I'd rather be safe than sorry.
Minivend is offline
Cam change worth it or not? hi$toy Engine Related 14 05-05-2017 09:43 AM
To change or not to change them, that is the question Steelerdude1 *General Road Glide Discussions/Pictures 2 07-18-2016 05:41 PM
Lifters: to change or not to change BigNorm Engine Related 14 01-19-2016 07:50 AM
Cam change or not??? g1shadow Engine Related 7 10-06-2014 11:00 AM
Not into leather but may change my mind after seeing this PAC MAN *General Road Glide Discussions/Pictures 3 12-09-2010 09:18 PM
