02 Roadglide doesnt start? - Road Glide Forums
post #1 of 16 (permalink) Old 07-18-2015, 05:53 PM Thread Starter
Question 02 Roadglide doesnt start?
My uncle has an 02 road glide. It occasionally has a problem of not starting. Like today we went for a ride.. Started fine. We stopped at a gas station to fill up. We were getting ready to leave when it decided not to start. Ignition and kill switch are on but when he hits the button to start it, it doesn't do anything.. But if he rolls it backward or forward a few feet and locks up the front brake and gives the bike a hard jerk, it starts. Any ideas? Loose wire? Loose connector? Inside the controls on the handle bars? Behind the fairing? As I said above though, it only does this once in a while
RyleDup0766 is offline
post #2 of 16 (permalink) Old 07-18-2015, 06:02 PM
JacktheBagger's Avatar
does it have an alarm system ?
if so some wifi hotspots will interfere with the alarms and you have to move the bike a bit to start it ..
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 16 (permalink) Old 07-18-2015, 08:01 PM Thread Starter
No, no alarm system
post #4 of 16 (permalink) Old 07-18-2015, 08:24 PM
Neutral or not?
reds4 is offline
post #5 of 16 (permalink) Old 07-18-2015, 08:52 PM
Maybe a sticking start relay?
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #6 of 16 (permalink) Old 07-18-2015, 09:09 PM
Im assuming when you say "doesn't do anything" that it's not cranking over? If so carry a small hammer or a decent sized screwdriver with you guys. Next time it doesn't start gently tap the starter while hitting the start button. Try this before you roll the bike. If it starts while you tap the starter then your starter needed to be replaced or rebuilt. If it still doesn't start then start checking for power at the starter wires.
post #7 of 16 (permalink) Old 07-18-2015, 09:16 PM
Do you hear a click when the starter button is pushed?
post #8 of 16 (permalink) Old 07-18-2015, 09:23 PM
Sounds about right.
Big_gary is online now
post #9 of 16 (permalink) Old 07-18-2015, 09:42 PM
Now, how many miles and is the white visible on Start Button?
reds4 is offline
post #10 of 16 (permalink) Old 07-19-2015, 10:16 AM
It happens once in awhile on my 08 and all I need to do is turn the ignition off and then back on and the bike starts fine. I don't know what causes the ignition to do this but it does.
Crank no start, crank start Sam07 Troubleshooting for Road Glides 10 05-15-2018 08:03 AM
Radio doesnt turn on need help. jprider4life Tech Area 3 08-04-2013 03:40 PM
02 Roadglide - TN $9400 Sincecrazy Classifieds Archive (3 months old+) 3 04-18-2011 01:39 PM
Kansas allowing motorcycles to run red light if it doesnt change. DED HD *General Road Glide Discussions/Pictures 15 02-24-2011 10:33 AM
