Explanation required please - Road Glide Forums
post #1 of 38 (permalink) Old 09-11-2012, 04:07 PM Thread Starter
Bigtrev8xl's Avatar
I see this all the time on all forums
"oil level too high,oil coming out of the air filter"
Can anyone explain why this should be,or is it another myth?
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #2 of 38 (permalink) Old 09-11-2012, 04:15 PM
OldNerdGuy's Avatar
Too much oil can increase the pressure on the crankcase ventilator in the heads, which causes the excessive oil to blow out the breathers, which drain into the air cleaner.
The Crankcase Breathers are meant to allow excessive AIR pressure in the crankcase to be vented into the intake. The excessive air pressure comes from the movement of the pistons. There are vents in the heads, and a valve, called the umbrella valve (because it looks like an umbrella) that allows the pressure to bleed into the intake. When there is too much oil, it makes it's way past the umbrella valves into the intake, saturating the filter, and leaking thru into the ham can, onto your leg, the exhaust pipes, the saddle bags, and making an all around mess of things.
OldNerdGuy is offline
post #3 of 38 (permalink) Old 09-11-2012, 04:35 PM Thread Starter
Bigtrev8xl's Avatar
The oil is stored in the oil tank/sump and not in the crankcase,how does this affect the pressure in the crank case?
I DON'T DO RUSHING!
post #4 of 38 (permalink) Old 09-11-2012, 09:13 PM
The complete oil system is under some pressure also the oil will expand some, that is why you are suppose to check the oil when hot while the bike is on the jiffy stand for a accurate oil reading according to HD instructions. Also as the oil flows through the oil tank/sump it creates a turbulence which results in higher oil level in the sump, That is why you only check the oil when the bike has been turned off for 3to5 minutes for a accurate reading. When the oil is overfull it has to vent someplace and on our bikes HD put the vent in the intake.
post #5 of 38 (permalink) Old 09-11-2012, 10:14 PM
Redfish-Joe's Avatar
Our motors hold 4 quarts dry. Meaning never had oil in it. You will retain nearly 1/2 quart after an oil change. Some in the sump, in the cam chest, gallerys, etc. If you put 4 full quarts back in after a change then by fault you have over filled by approx. 1/2 quart. That's what winds up in the filter media.
Redfish-Joe is offline
post #6 of 38 (permalink) Old 09-12-2012, 05:31 AM Thread Starter
Bigtrev8xl's Avatar
Surely the amount of oil remains the same in the engine crankcase because the oil is constantly removed by the scavenge pump, regardless of how much oil is in the oil tank/sump
I DON'T DO RUSHING!
post #7 of 38 (permalink) Old 09-12-2012, 05:40 AM Thread Starter
Bigtrev8xl's Avatar
I'm not asking how people change their oil,how they change it is immaterial,
if people do it the way you suggest they are doing it wrong, and that doesn't explain how the excess oil gets from the oil tank/sump to the air filter.
I DON'T DO RUSHING!
post #8 of 38 (permalink) Old 09-12-2012, 06:00 AM
4getNo1's Avatar
Come on Bigtrev8xl. You've received answers to your question plus some related potential causes.
Take it easy man. Please consider that your responses make is seem as though you have already determined that those answers and causes are myths.
Surely you wouldn't already know more about the way things work in a Harley engine and oiling system than the folks who are trying to offer answers or you wouldn't have asked the question in the first place.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #9 of 38 (permalink) Old 09-12-2012, 06:14 AM
4getNo1's Avatar
ETA - As for the "myth" part of your question, check this thread:
https://www.roadglide.org/showthread.php?t=10451
4getNo1 is offline
post #10 of 38 (permalink) Old 09-12-2012, 08:10 AM
4getNo1's Avatar
Now for my answer to your question:
Modern EPA regulations are complied with by venting hot engine gasses and the related pollutants into the intake rather than directly to the external atmosphere. Any oil, even in vapor form, that gets into that venting system is therefore often carried into the intake along with those hot gasses.
The main objective is to either burn pollutants during combustion and let the Catalytic Converter handle the residue or "re-breathe" them by re-routing them back into the engine.
However, if the crankcase of a wet-sump type engine is filled with oil far enough so that oil level intrudes into an input for the venting system, then that issue is quite apparent since the air cleaner can become saturated. Hence, "...oil coming out of the air filter".
4getNo1 is offline
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 10:51 AM
National Call to Action - Immediate Action Required JohnnyG General Off-Topic Discussions 0 06-04-2012 02:09 PM
Is HD maintenance required for Warranty?? Sydvicioustx *General Road Glide Discussions/Pictures 8 01-31-2012 06:50 PM
How Much Dyno Time is Required? bane1240 ECM/Fuel Management systems 9 09-14-2011 09:54 AM
