Trouble codes on a 2004 - Road Glide Forums
post #1 of 5 (permalink) Old 08-15-2015, 07:07 PM Thread Starter
Clutch1's Avatar
How do i read what the codes are? Key light is on indicating a current problem but cant find the how to get the codes to display. Any help out there? Thanks.
Chuck
Clutch1 is offline
post #2 of 5 (permalink) Old 08-15-2015, 09:45 PM Thread Starter
Clutch1's Avatar
Ok so when i go theough the run/odometer/ignition process i cannot access the dtc portion. All i get is mileage and the red key light stays on. Any thoughts?
Clutch1 is offline
post #3 of 5 (permalink) Old 08-16-2015, 06:19 AM
100edition's Avatar
Not sure you can access them on a 04. You can clear them by cycling the switch 50 times. Ask Ironmark. He just shared this information with me about my 03.
100edition is offline
post #4 of 5 (permalink) Old 08-16-2015, 08:11 AM Thread Starter
Clutch1's Avatar
I checked the fuses and i had a blown access fuse. Put a new one in and all the gauges and access to the diagnostic mode came back. No codes present but all is working again.
Clutch1 is offline
post #5 of 5 (permalink) Old 09-10-2015, 04:25 PM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
Codes
I know it sounds like you've done this, but hold the reset button down, turn the switch to on, and you should be in the DTC feature. Make sure the stop/run switch is in the run position prior to starting the procedure. Let us know if you have any luck.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
How to Find your Diagnostic Trouble Codes ironmark Troubleshooting for Road Glides 42 05-03-2019 06:43 AM
Butt load o' trouble codes shrtyonasprty Troubleshooting for Road Glides 10 09-23-2017 12:27 PM
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 12:56 PM
2001 trouble codes flfishhook Troubleshooting for Road Glides 3 01-10-2012 05:08 AM
Road glide error codes beachbum Troubleshooting for Road Glides 3 10-10-2010 12:56 PM
