HD High Output Charging System - Road Glide Forums
post #1 of 4 (permalink) Old 08-25-2015, 10:12 AM Thread Starter
09Sharknose's Avatar
Has anyone ever installed or had any experience with HD Part # 29900028 High Output Charging System?
It claims 54 amps @4000 rpm which means it has lots of power on hard acceleration.
I installed a subwoofer and amp that kills my charging system. Looking at this as an alternative to the accessory battery in my tourpak.
Thanks!
09Sharknose is offline
post #2 of 4 (permalink) Old 08-25-2015, 10:19 AM
The high output charging system is only 4 amps over stock which is 50 amps. I don't think 4 extra amps is going to solve your problem. Installing as many LED lights as you can will help reduce draw on the charging system directing more current to the battery.
post #3 of 4 (permalink) Old 08-25-2015, 11:00 AM Thread Starter
All of my lighting is LED.
They only show 4000 rpm amperage, that's not where I hang out most of the time, they (HD) claim 30% increase at 1000rpm. I haven't found any numbers between 1k and 4k rpm, which is where most riders are most of the time.
post #4 of 4 (permalink) Old 08-25-2015, 12:28 PM
eme56's Avatar
Take a look at the kits from Cycle Electric. Their replacement system (VR, Stator, & Rotor) puts out 35 amps at 1000 RPM and 54 amps at 2500 RPM. I just replaced my old 45 amp single phase system (2005 & earlier) to their 3 phase system when my VR went out. It has made a very noticeable difference. You already have a slightly more powerful 3 phase charging system in your bike, so it won't be as noticeable, but the Cycle Electric system is about the same price or lower as the Harley high output system.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
Bikes Charging system Vs. High End stereos Taz_FL Audio 8 03-22-2018 08:12 AM
High output Charging kit....??? maddmoe Aftermarket Accessories 0 07-23-2016 08:08 PM
iPhone 4S - Charging/Not Charging dinggus Audio 8 11-01-2013 08:25 AM
Video: Fuel Moto Jackpot 2 into 1 Exhaust System w/ High Output Core cyclescoot Intake and Exhaust 9 03-18-2013 06:22 PM
Electrical System Not Charging jimmyray11349 Troubleshooting for Road Glides 3 03-23-2012 07:31 AM
