Circuit Additions - Road Glide Forums
post #1 of 21 (permalink) Old 09-26-2012, 09:24 PM Thread Starter
cobra206's Avatar
Circuit Additions
I have recently added a bunch of electrical accessories to my 2012 Road glide. Hard Wired GPS, Internal Antenna, Additional 12 Volt Accessory port. Right now all of the above are wired to the stock 12v accessory port. I am concerned that under some instances i might over load that circuit.
From what i know (and i could be wrong) that circuit is on a 15amp fuse wired to the bikes fuse box.
i want to clean up the wiring in my fairing by moving the wiring from the GPS ( which is currently just bunched up and wire tired to the radio harness) along the back bone, thereby cleaning up the fairing. I want to run the wire into the fuse box eliminating the inline 7.5amp fuse and adding a 7.5amp fuse port into my fuse box in an empty spot.
I understand that this isn't really necessary but i don't like seeing all those wires bunched up in my fairing.
My questions are:
1. Is it possible to add a switched circuit to the fuse box without any major modifications to the bike?
2. Should i consider purchasing an additional fuse box to place in the fairing instead of just tapping off the 12v switched circuit (12v accessory port)?
3. Am i asking for trouble to keep running all my accessories off that one circuit?
My thinking is if in the event i need to change a blown fuse i would rather remove the seat than the fairing... also i plan on adding more electrical items (leds on the body and speakers) so i just want to make sure i am not going to overload that particular circuit....
Any suggestions or ideas would be greatly appreciated...
cobra206 is offline
post #2 of 21 (permalink) Old 09-26-2012, 10:40 PM
Triplej's Avatar
Check out www.fuzeblocks.com.
Might be just what you need.
Triplej is offline
post #3 of 21 (permalink) Old 09-26-2012, 10:59 PM
Mischief's Avatar
I installed 2 20 amp relays with a fuse running each supply wire from the battery into my fairing. One is switched from the ignition, the other from the accessory switch. It is not to difficult if you are pretty good with wiring. I haven't had an issue yet. ( hopefully I don't jinx myself)
2012 FLTRU
Mischief is offline
post #4 of 21 (permalink) Old 09-26-2012, 11:56 PM Thread Starter
cobra206's Avatar
Thanks TripleJ, that website was very helpful. I might have to invest in one of their units.
Does anyone know how to add a fuse/circuit to the existing fuse box?... i would preferably like to keep all my fuses under the seat for easy access.
If i go with the FZ-1 fuse box, what wires would i tap for the switched circuit? i assume i could use the 12v accessory port +lead or do i have to use the orange wire pigtail from the headlight harness?
cobra206 is offline
post #5 of 21 (permalink) Old 09-27-2012, 05:06 AM
Bigtrev8xl's Avatar
Not a problem ,but don't be tempted to increase the fuse rating.
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #6 of 21 (permalink) Old 09-27-2012, 11:47 AM
DC-3Mek's Avatar
I know a good bit about wiring/electronics....let me be a bit more vocal than BigTrev8xl........NEVER increase a fused circuits fuse! You open yourself up for a fire!!!I"
Let me state the overly obvious.....the reason the fuse is in there is to protect you from exactly that!!! And if it came from the dealer/factory/store whatever with the fuse in it.....USE that fuse exclusively!
Trust me brother.....you get a LONG time...(a millisecond in reality) to wonder if your "Boys" are gonna go "Toasted" on you if you get a fire while cruisin' down the interstate!!!
and DON'T ask me how I know!!!......suffice it to say.....that was BEFORE I knew a lot about wiring!!! LOL!!!
DC-3Mek is offline
post #7 of 21 (permalink) Old 09-27-2012, 12:19 PM
faststan's Avatar
I use this one for accessories:
http://www.rivcoproducts.com/product...detailedImages
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #8 of 21 (permalink) Old 01-19-2013, 11:30 AM
BigBlue103's Avatar
I did this when I installed HD heated grips. It really isn't too difficult. You'll need to attach a fuse connector to the end of your switched power wire and insert it into the fuse block. Take a look at the diagram on the fuse block cover to see which ports are available for the amperage you need.
I have to admit, this was easy for me because the instructions told me which port to use. Be careful. Screwing up electrical is very easy and only has to happen once to FUBAR a bike.
The aftermarket fuse block looks like a great option to me. You could install it under the seat for convenience and extend the wires to the added accessories. The great thing about the added fuse block is that if it fries, you can disconnect it, throw it away and the bike is back to original.
'13 FLTRX in Big Blue Pearl
Paso Robles, CA
BigBlue103 is offline
post #9 of 21 (permalink) Old 01-21-2013, 10:43 AM
sonic_cruzer's Avatar
I installed this external fuse box. Since it has 2 separate circuts I had one connected to switched 12V and one to ACC 12V. It is kinda nice having that capability.
http://www.easternbeaver.com/Main/Wi...PC-8/pc-8.html
2008 Vivid Black RG, CB TRSSC, Ohlins #2~#2B on Rear, -1" Progressive Monotubes in forks, RP EMS Tuner, TW-222 cams, Kromewerks Sweeper +2 bars, Rivera Pro VP Clutch, SuperTrapp 2:1 Exhaust, SE Compensator, Medallion Gauges, UltraCool, all lighting is LED including Daymakers.
sonic_cruzer is offline
post #10 of 21 (permalink) Old 02-25-2013, 08:10 PM
+1 on the EasternBeaver. Very good quality. I am afraid to add accessories by tapping into other lines. A switchable fuse block is the BEST way to power up accessories. The PC-8 also has two circuits that are not switchable. This is nice for charging the phone in the saddlebag while you are away from the bike.
Deano is offline
lower fairing speaker additions LoweBudget Audio 2 02-15-2016 07:49 PM
Best Additions ? Is it cheaper to keep her? Meatpacker *General Road Glide Discussions/Pictures 10 12-20-2014 05:23 AM
Wrapping up additions Jasondoow Controls & Handlebars 4 02-27-2014 10:58 PM
A few additions Rooster *General Road Glide Discussions/Pictures 8 08-18-2013 08:31 PM
Underseat Tap-in to the Aux circuit? mdwar2005 Tech Area 1 05-09-2011 09:07 PM
