Primary and transmission fluid question ? - Road Glide Forums
post #1 of 15 (permalink) Old 09-30-2012, 07:23 PM Thread Starter
Road dawg's Avatar
I have a question? i was told by the dealer that running amsoil 20W50 in the primary would cause premature wear and possible failure? that i should only be running primary oil or 75W90 syn ? second question should i run 75W90 amsoil in the transmission as well? Help please
Road dawg is offline
post #2 of 15 (permalink) Old 09-30-2012, 07:43 PM
Desertwndrr's Avatar
Lots of people run Mobil 1 20w/50 in the primary. Harley recommends Syn3 which is a 20w/50. I don't see why the Amsoil wouldn't work as long as it's JASO rated.
There are also lots of folks that run the 75w/90 gear oil in the transmission with no issues.
Personally I run a 10w/40 or Formula+ in the primary and 75w/140 Mobil1 gear oil in the transmission.
Desertwndrr is offline
post #3 of 15 (permalink) Old 09-30-2012, 08:05 PM Thread Starter
Road dawg's Avatar
Thanks for the info,my local bike shop told me to run vtwin primary and 75W90 in the trans ,which would be syn amsoil as well.
post #4 of 15 (permalink) Old 10-01-2012, 02:18 PM
scubaz71's Avatar
I run mobil 1 v-twin in the engine, HD formula in the primary and Bel ray big twin transmission fluid in the tranny.
Traded- 2012 BBP FLTRX, Tmax, Heavy Breather,Dragula, TW222 cams, swinebox.
Current-2016 CBP Ultra,race tuner,chisel intake,agitators and started the blackout process
scubaz71 is offline
post #5 of 15 (permalink) Old 10-01-2012, 04:15 PM
rageglide's Avatar
I've been running ATF (dexron IV - for GM transmissions) for years and years in everyone one of my primary's, Shovel, Evo, my 2005 twinkie, and plan to use in 2012 also.
I use Redline Shockproof heavy in my transmission, the V-Twin stuff is orange, if that's not a reason I don't know what is! ;-)
That's just my preference. I would never use a heavy oil synth or motor oil in the primary. An automatic car transmission is far more hostile environment than our primaries comprised of friction materials and roller bearings, deja vu.
I also would never run that flawed POS OEM automatic tensioner. I've got a fixed shoe on the way.
rageglide is offline
post #6 of 15 (permalink) Old 10-01-2012, 07:31 PM
torqu's Avatar
Why would you want to run a full synthetic in the primary? You need some kind of friction between the disc. I thought the only reason there was any oil in the primary was to lubricate the sprockets and chain. I dont run synthetic in my primary for those reasons. I run a primary oil made by Spectro.
torqu is offline
post #7 of 15 (permalink) Old 10-01-2012, 08:07 PM
Torquey's Avatar
Perhaps, but on my FatBoy, the clutch was buttery smooth and precise with Amsoil. With my new Glide, I am going to try the dedicated RedLine Primary fluid. Both are fully synthetic.
Torquey is offline
post #8 of 15 (permalink) Old 10-02-2012, 08:42 PM
I have an 03 road glide and found a leak coming from the sprocket closes to the engine can any body have any ideas where that might be coming from?
Sent from my iPhone using MO Free
Loudog is offline
post #9 of 15 (permalink) Old 10-03-2012, 12:31 AM
rageglide's Avatar
Using different colored fluids helps isolate these kinda things. Trans will leak from the main seal and sector shaft. Primary can leave at the engine o-ring and also at the 4 trans mounting bolts. Inner mainshaft and of course Primary can leak all along the outer primary gasket...
Lots of places... so yer gonna have to crawl, wipe and look. With ATF in the primary I know when it's leaking, redline shockproof tranny oil leaves a pink spot...
post #10 of 15 (permalink) Old 10-12-2012, 07:27 PM Thread Starter
Road dawg's Avatar
Thanks for everyones input it was much appreciated !
Transmission fluid into primary Lima14 Engine Related 38 10-30-2018 11:47 AM
Transmission Fluid NavyRGSRider *General Road Glide Discussions/Pictures 9 04-15-2018 05:00 PM
Low transmission fluid in M8 2016CTRoadGlide Engine Related 14 06-22-2017 02:38 PM
Transmission fluid issue Chico1960 Fluids and Lubricants 10 10-19-2016 11:54 PM
DIY-Oil/Transmission Fluid change videos..... CRAIG2 Videos 2 05-13-2011 11:11 AM
