De-pin Tool - Road Glide Forums
post #1 of 15 (permalink) Old 09-17-2015, 06:21 PM Thread Starter
Q-Hog's Avatar
De-pin Tool
Anyone have info of what tool is used to De-pin a wire out of the HD disconnectors and where can I get one?
Q-Hog is offline
post #2 of 15 (permalink) Old 09-17-2015, 06:32 PM Thread Starter
Q-Hog's Avatar
These are the types of pins that I have to remove from the connector.
Q-Hog is offline
post #3 of 15 (permalink) Old 09-17-2015, 08:25 PM
Do you have a picture of the connector?
Darkdx is offline
post #4 of 15 (permalink) Old 09-17-2015, 08:48 PM
this one should work I don't have it but its for the deutsch connectors
2001 Road Glide Jade Sunglo , carb and stock
Eagle is offline
post #5 of 15 (permalink) Old 09-17-2015, 08:58 PM
shermanator's Avatar
Do a search on the forums. There is pictures and instructions. Use small pick or paperclip from the back side of connector. There is a tab on the pin side you have to pop up first. Its been a while since I did it .
shermanator is offline
post #6 of 15 (permalink) Old 09-17-2015, 09:04 PM Thread Starter
Q-Hog's Avatar
Thx guys.
Q-Hog is offline
post #7 of 15 (permalink) Old 09-17-2015, 09:08 PM Thread Starter
Q-Hog's Avatar
Dark, Here's the pic of the connector. It's for the saddlebag lid LED spoiler.
Q-Hog is offline
post #8 of 15 (permalink) Old 09-18-2015, 06:34 AM
skratch's Avatar
check your local napa.
skratch is offline
post #9 of 15 (permalink) Old 09-18-2015, 06:54 AM
For some reason I can't see the picture but more than likely like what shermanator said is that there's going to be a lock, remove that and use a small flat tip or a paper clip, you should be able to see a little tab that you have to either push up or pull down and the pin will release from the back side of the connector. Someday I'll have to do a diy on how to de pin connectors as I was a wiring tech.. I've honestly never had to buy a de pin tool.
Darkdx is offline
post #10 of 15 (permalink) Old 09-18-2015, 06:55 AM
lil chief's Avatar
A dental pick usually works pretty well. You can pick up a set at Harbor Frieght for about $5.
Lil Chief
ADD: You might have to remove that white piece in the middle of the connector first before you can get the pins out. That should pop out of the housing if I remember correctly.
RGKen likes this.
lil chief is offline
Molex MX150 De-Pin Tool wevsspot *General Road Glide Discussions/Pictures 12 05-04-2018 08:55 AM
Which Molex pin connector tool 16 Road Glide Special ??? wheredugo Controls & Handlebars 16 03-29-2017 11:29 AM
Pin Striping dklanecky *General Road Glide Discussions/Pictures 26 05-26-2010 04:52 AM
Wire color for pin 7 on Gray L handle bar plug? Sincecrazy Controls & Handlebars 1 03-06-2010 08:54 AM
HD Pin Strip Logo ncbeast *General Road Glide Discussions/Pictures 0 12-09-2009 07:09 AM
