new tire rubbing on drive belt - Road Glide Forums
post #1 of 8 (permalink) Old 10-20-2012, 07:57 PM Thread Starter
I just installed a Michelin commander 2 on my 2001 roadglide and the drive belt is rubbing on the tire 140/90/16,I hv been using Metzler and avons that size and I didnt hv this problem,Does any one hv a solution to this, I would appreciate any help I can get thks .
saccman is offline
post #2 of 8 (permalink) Old 10-20-2012, 09:02 PM
Did you line up the rear axle correctly??
post #3 of 8 (permalink) Old 10-20-2012, 10:08 PM
Triplej's Avatar
Is it possible you have the axle spacers in the wrong positions? From the parts drawings you have 2 axle spacers that are of different sizes and the 43654-00 seems to be longer and should be on the brake disc side. The shorter one (40981-00) should be on the sprocket side.
Here is a link showing how the spacers should be.
http://partsfinder.onlinemicrofiche....SK-AND-SPOCKET
Triplej is offline
post #4 of 8 (permalink) Old 10-21-2012, 09:02 AM Thread Starter
i have the adjusters correct,the spacers I have the long one on the drive belt side,and the shorter is on the rotor side.
saccman is offline
post #5 of 8 (permalink) Old 10-21-2012, 09:49 AM
Triplej's Avatar
According to the parts drawing you have the spacers reversed.
Triplej is offline
post #6 of 8 (permalink) Old 10-21-2012, 06:50 PM
look again.
SickRick is offline
post #7 of 8 (permalink) Old 10-21-2012, 08:47 PM
Triplej's Avatar
Originally Posted by SickRick View Post
look again.
Just did and not sure what your are looking at. The spacers I am talking about or items 20 (43654-00) and 10 (40981-00) in the parts drawing. Maybe you are confusing item #19? If so, that spacer is sandwiched between the bearings and unless the OP changed out the bearings it should not come into play. Then again it is a drawing I am looking at and maybe they look different in person??
Triplej is offline
post #8 of 8 (permalink) Old 10-24-2012, 04:53 PM Thread Starter
My tire rubbing must be that I went up a size six tires ago and didnt have a problem with the width of the Metzers I was using.So now Im exchanging my Michelin Commander 2 tire for a smaller size 130/90/16 so I hope this works,stay tuned and thanks guys for all the advice.
saccman is offline
Tire rubbing after replacement at HD dealer mineman Suspensions 6 02-20-2015 08:10 AM
21" & tire rubbing problems DemonCity *General Road Glide Discussions/Pictures 11 09-12-2011 07:53 PM
Front tire seems to be rubbing Stray Mutt *General Road Glide Discussions/Pictures 2 05-05-2011 11:29 PM
Belt Drive Limited Compensator mrbill Troubleshooting for Road Glides 0 12-19-2010 08:00 AM
Tire rubbing alhdrider Aftermarket Accessories 0 05-24-2010 11:00 PM
