Primary clicking - Road Glide Forums
 5Likes
post #1 of 33 (permalink) Old 03-15-2016, 05:59 PM Thread Starter
! rock103 !'s Avatar
Primary clicking
Just noticed a clicking noise as I was backing the bike up in the garage while not running today. Started it up and put in first gear to pull it forward and shut engine off. Backed up again and clicking noise remained. The clicking speeds up the faster you back up. My guess is tensioners? Called and made an appt for them to check it out under warranty at the dealer. Any thoughts on what it may be?
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #2 of 33 (permalink) Old 03-15-2016, 06:14 PM
mocotom's Avatar
Your moving the bike without it running so it can't be the chain tensioner because the chain isn't moving without the motor running. You will sometimes get a clicking or squeaking noise from the drive belt when backing up. The belt tries to shift to the inside of the sprocket and causes the noise. It will not make the noise when you push it forward because the belt centers itself again
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 33 (permalink) Old 03-15-2016, 06:46 PM Thread Starter
Gonna take it for a spin for a whiskey run and see if it continues...
post #4 of 33 (permalink) Old 03-15-2016, 09:12 PM
idahointrudr's Avatar
Mine squeaks pretty good when i back it up. Makes a little more than a squeak sometimes.
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #5 of 33 (permalink) Old 03-15-2016, 09:31 PM Thread Starter
Decided to do a couple videos to show what I am hearing.
Forward:
https://youtu.be/ME_N0ZP48aA
Backward:
https://youtu.be/6gn-1wpsi5M
post #6 of 33 (permalink) Old 03-16-2016, 04:34 AM Thread Starter
Sounds like something other than the final belt to me.
post #7 of 33 (permalink) Old 03-16-2016, 04:49 AM
immo2896's Avatar
That is not a belt, but does the noise change if you pull the clutch in? Just trying to picture in my noggin what is turning with the engine off.
immo2896 is offline
post #8 of 33 (permalink) Old 03-16-2016, 04:59 AM
RGKen's Avatar
Do you still have the baseball card in the spokes?
immo2896 likes this.
2018 FLTRXS
RGKen is offline
post #9 of 33 (permalink) Old 03-16-2016, 05:01 AM
RGKen's Avatar
Seriously though... Have you tried putting it on a jack and moving the rear tire? Are your brake pads still good?
2018 FLTRXS
RGKen is offline
post #10 of 33 (permalink) Old 03-16-2016, 08:03 AM
tdkkart's Avatar
Soumds to me like your belt is too tight.
Sent from my SPH-L710 using Tapatalk
tdkkart is offline
clicking, no start uncommon Troubleshooting for Road Glides 7 07-24-2013 01:22 AM
Ignition Switch Clicking jimmym1981 Troubleshooting for Road Glides 8 03-30-2013 10:50 AM
primary cover black-glide Troubleshooting for Road Glides 2 01-17-2011 07:15 PM
Primary locking bar? JefFLH Engine Related 5 11-16-2010 05:20 PM
Inner primary seal vinchenz07 Troubleshooting for Road Glides 5 04-30-2010 10:00 PM
