2015 brake pulsation - Road Glide Forums
 2Likes
post #1 of 16 (permalink) Old 03-27-2016, 09:51 PM Thread Starter
I recently upgraded to a 21" 18" wheel set for my 2015 Shark. new rotors, abs bearings, etc. I am now getting a brake pulsation when stopping at low speeds. Being that I have the linked braking system I can't tell whether its from the front or rear. I've bleed the brakes, and the rotors measure perfect. Has anyone had this issue or have any ideas on how the get rid of the pulsation?
thanks in advance.
Fresh_Glide is offline
post #2 of 16 (permalink) Old 03-27-2016, 10:24 PM
Q-Hog's Avatar
I have that situation as well. Mine is from the front. I assume it's my rotor being warped.
Q-Hog is offline
post #3 of 16 (permalink) Old 03-27-2016, 11:07 PM
hifiho's Avatar
Your ABS operates via speed sensors on the axle vs magnets in the bearings. When the circumference of the tire changes, it will send a false speed reading to the ABS computer. The ratio the computer sees as "correct" is based on the OEM tire sizes. When the tire size is changed, and the ratio is no longer the same, the ABS system reacts when pressure is applied to the brakes to force them to travel at the same speed. If the ratio is modified- without correction- it will "pulse" the calipers on whichever wheel is travelling too fast.
This seems like a dangerous situation. YOUR tire "upgrade", without proper calibration might only serve to make your bike look really cool right before you wreck it. Because you've modified the way the tires vs. brakes are *supposed* to perform, it may cause brake lockup due to the incorrect speed sensor ratio.
I could be completely off-base. But basic physics says that's where the problem lies.
scooterh72 likes this.
'15 Road Glide Special...'08 Night Rod Special...'04 Stage 4 113 CI Softail Deuce (Beast Mode)
hifiho is offline
post #4 of 16 (permalink) Old 03-27-2016, 11:29 PM
Q-Hog's Avatar
I have a stock set up. So my issues might be caused from a different situation. Thx
Q-Hog is offline
post #5 of 16 (permalink) Old 03-27-2016, 11:50 PM
hifiho's Avatar
[QUOTE=Q-Hog;3276617]I have a stock set up. So my issues might be caused from a different situation. Thx
Sounds like YOUR diagnosis is correct. Do the forks "dive" as the brakes pulse? If so, that DEFINITELY sounds like warped rotors.
hifiho is offline
post #6 of 16 (permalink) Old 03-28-2016, 12:36 AM
Q-Hog's Avatar
My Wheel vibration is felt when front brakes are applied.
Fresh glide might need that device that's been mentioned for adding a 21" wheel to a RGS.
Q-Hog is offline
post #7 of 16 (permalink) Old 03-28-2016, 04:32 AM
UT_Larry's Avatar
My understanding is when the abs brakes are bleed it requires a dealer only machine to do it correctly. Some brakes completely lock up. I could be wrong.
UT_Larry is offline
post #8 of 16 (permalink) Old 03-28-2016, 06:59 AM
Smarty's Avatar
Did you happen to put chrome rotors on your bike before this starting happening?
2016 RGS Black Quartz
Smarty is offline
post #9 of 16 (permalink) Old 03-28-2016, 07:03 AM
Smarty's Avatar
A way to find out which one it is Qhog, pull one side caliper off, put an old brake pad between the brake pad on the caliper that you took off and zip tie it in there and zip tie it to your crash bar. Think ride the bike on a test ride and see if it still does it. IF it does, that's the warped brake rotor, if not, put it back on and do the same to the other side. Easy way to find out which it is. IF you don't have a spare pad, use something you can zip in there to prevent the caliper from closing up all the way. I think you get what I'm talking about. Good luck finding it.
Smarty is offline
post #10 of 16 (permalink) Old 03-28-2016, 07:56 AM Thread Starter
I do have the correct abs bearings for the wheel and tire size upgrade. If it was incorrect the ABS light should come on correct?
Soft Brake chrome slotted Brake Pedal longrides Sold 7 05-17-2013 08:03 PM
Billet brake lever installed for rear brake HUTMO Do-IT-Yourself 1 12-27-2012 03:18 PM
Dual brake set up to single side brake Q-Hog Wheels and Tires 12 08-01-2012 11:55 AM
Changed rear brake arm now almost no rear brake? ncbeast Troubleshooting for Road Glides 4 05-30-2011 09:13 PM
Front Brake Pulsation? FLTRI *General Road Glide Discussions/Pictures 8 02-25-2011 04:45 PM
