Battery Tinder Pigtail - Road Glide Forums
  • 1 Post By '05Train
post #1 of 6 (permalink) Old 05-08-2016, 10:30 AM Thread Starter
UltraWalt's Avatar
The connection or pigtail in my opinion is in a not so easy place. Where are you guys running this pigtail so that you don't have pull the saddlebag and side plate?
2016 RGUltra
2019 Roadglide Ultra
UltraWalt is offline
post #2 of 6 (permalink) Old 05-08-2016, 10:45 AM
TYM2GLIDE's Avatar
2016 RGUltra
Not sure about the 16s, but my 12 RGC the pigtail hangs in front of the side panel just above the oil dipstick. I have it zip-tied to the rail.
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #3 of 6 (permalink) Old 05-08-2016, 10:51 AM
Smarty's Avatar
There is a slot at the bottom of the housing that you stick the wire out of and put the cover back on. It really disappears nicely. I just have the very end sticking out.
2016 RGS Black Quartz
Smarty is offline
post #4 of 6 (permalink) Old 05-08-2016, 01:54 PM Thread Starter
UltraWalt's Avatar
Thanks Smarty! I will do exactly that. I tried running it up top between the seat and the top of saddlebag and it works but, I'm worried that the cord will scuff up the side plate.
post #5 of 6 (permalink) Old 05-08-2016, 03:05 PM
I did the same thing at first but I still didn't like it. I think it's in a bad spot no matter what you do. When you plug the tender into it there is a chance of the wire resting on your hot pipes.
I have heated gear and needed a Coax connection and up higher so it is easier to plug in the heated gear. Like we used to I wired the pigtail to the battery and have it tie wrapped to the saddlebag crash bars I have installed. I have an adapter to SAE for the tender. I also like that it goes directly to the battery instead of somewhere in the harness?
I neatly placed the factory one back where it started. Just giving other ideas/opinions. What works for me might not work for you.
thealien is offline
post #6 of 6 (permalink) Old 05-08-2016, 05:54 PM
'05Train's Avatar
When my bike was PDI'd they apparently didn't know what to do with it. So they had it up against the belt. Now I have half a tender lead.
Smarty likes this.
'05Train is offline
Battery tender pigtail routing jeffle64 Aftermarket Accessories 9 08-29-2018 01:20 PM
Locating the aux. light pigtail on the 13' RGC lundboy1 Lighting 2 04-14-2013 10:26 PM
Battery pte359 Aftermarket Accessories 31 02-21-2012 09:18 AM
Sumax 2 gauge battery cables fleabite *General Road Glide Discussions/Pictures 4 11-22-2010 06:34 PM
Turn signals erratic after installing trailer pigtail Sincecrazy Lighting 5 09-07-2010 06:39 AM
