Help . . can't remmove antenna from radio - Road Glide Forums
post #1 of 4 (permalink) Old 01-01-2013, 02:39 PM Thread Starter
Wild Bill Coady's Avatar
So I have been pulling at the antenna plug and it slides in and out but seems to get hung before it comes out of the back of the radio....Is there a trick to removing? I don't want to force or break anything??
RUBBER SIDE DOWN . . . the other way just hurts!
2011 Road Glide Ultra
2003 Electra Glide Classic (RIP 9/3/11)
1987 XLH 1100 30th Anniversary
Wild Bill Coady is offline
post #2 of 4 (permalink) Old 01-01-2013, 02:46 PM
Never heard that before, is there a clamp on the cable or anything like that, how hard are you pulling?
post #3 of 4 (permalink) Old 01-01-2013, 04:45 PM
Govdog76's Avatar
Yeah, not normal- it should just slide right off with a good solid tug. I know this is obvious, but have you tried turning and pulling at the same time?
If you do end up buggering something, the guys at Iron Cross audio are great to work with and have fast the around times. Good luck.
Ian
Govdog76 is offline
post #4 of 4 (permalink) Old 01-07-2013, 07:12 AM Thread Starter
Thanks for the input . . .I was a bit too tentative you with a solid pull it came out. The plug was actually longer than I expected.
Sent the tach, speedo and radio face off to Marty for the blue light treatment.
Remove Rear Antenna- Add Hidden Antenna- Hurt Reception? scottrgs Audio 4 09-06-2017 11:34 AM
I Can't Wait I Can't Wait I Can't Wait......The Outdoors SteadyEddie General Off-Topic Discussions 15 05-19-2017 03:57 PM
Antenna, go with a hidden or can I remove it? Mooseinthetub Audio 17 02-22-2016 04:55 PM
Can I run NO CB antenna adown Audio 15 07-22-2013 10:09 AM
Can't get factory radio out...Help scuba1954 Audio 4 10-03-2012 04:44 PM
