08 road glide (throttle problem - Road Glide Forums
 2Likes
  • 1 Post By Big_gary
  • 1 Post By hoosierboarder
post #1 of 9 (permalink) Old 06-27-2016, 03:47 PM Thread Starter
This has happen about three times in the last month. Rideing along and suddenly no throttle and check engine light goes on. Pull over the bike is still running . Turn it off reset the ignition switch starts and runs fine again. Any help would be appreciated
Thanks CB
Bacanater is offline
post #2 of 9 (permalink) Old 06-27-2016, 04:39 PM
FDR's RGC's Avatar
Check your connection at twist sensor. The little green plug has been known to cause problems.
FDR's RGC is online now
post #3 of 9 (permalink) Old 06-27-2016, 05:49 PM Thread Starter
Where is the green plug located
post #4 of 9 (permalink) Old 06-27-2016, 06:26 PM
ERod62's Avatar
Did you check DTC error codes?
Green connector end of the TGS
Either inside handle bars or in the cable run out side the bars. Green plug POS cut and solder wires using shrink tubing.
ERod62 is offline
post #5 of 9 (permalink) Old 06-27-2016, 07:30 PM Thread Starter
Ok thanks, I will start there. I appreciate your help
post #6 of 9 (permalink) Old 06-27-2016, 08:40 PM
You really need to recover the error codes.
hoosierboarder likes this.
Big_gary is online now
post #7 of 9 (permalink) Old 06-28-2016, 11:19 AM
hoosierboarder's Avatar
More than likely (without knowing the codes) it would be the TCA(throttle control actuator) pull the plug off behind the air cleaner. put some dielectric grease on the pins & reconnect, clear the codes. Happens about every 5k miles on mine.
ironmark likes this.
'09 Road Glide
hoosierboarder is offline
post #8 of 9 (permalink) Old 06-28-2016, 11:50 AM
There is a lot of info in the troubleshooting section that can help you with your problem.
The TCA plug on the throttle body is the problem not the green connector inside the handlebars.
post #9 of 9 (permalink) Old 06-28-2016, 03:26 PM Thread Starter
Thanks for your help.
Chris
No throttle 08 road glide Bacanater Troubleshooting for Road Glides 8 05-28-2018 06:38 AM
Very loud clank when shifting or getting on throttle or letting off throttle Callahan69 Engine Related 28 11-14-2016 01:09 PM
08 Electra Glide - Cruise Control Problem gaillarry Controls & Handlebars 7 03-29-2013 03:34 PM
08' Ultra Tour pack to 08' Road Glide Chain Link Aftermarket Accessories 2 03-02-2013 04:17 AM
08 glide Power Commander mounting problem skidmark1964 Troubleshooting for Road Glides 0 09-14-2012 11:40 AM
