Adding King Tour Pak (with lights) to a Special - Road Glide Forums
 2Likes
post #1 of 16 (permalink) Old 07-12-2016, 03:51 PM Thread Starter
psrumors's Avatar
Today I drilled my Tour Pak to accept the OEM led light bar. I was worried I would screw up using a template so I spent a little extra money, got a donor light and made a template out of it. I closed up all the holes that were not to be drilled and marked all of the holes to be drilled with some paint....didn't want to take any chances of drilling in the wrong place
The template enabled me to clamp the light bezel in place, drill my holes and mount the new light in short order.
I stopped to take a pic before finishing the big hole for the light connection as I didn't want to forget to show a pic of the holes
And here it is mounted.
Next will be wiring it up.
One thing I am unsure on is the CB antenna and why Harley didn't bring the full coax to the antenna base like they do on the AMFM antenna. The same antenna base will work on the CB side and it could still be grounded to the metal plate in the base of the tour pak like the AMFM antenna setup.
Anyone know?
psrumors is offline
post #2 of 16 (permalink) Old 07-12-2016, 03:59 PM
eddienelson's Avatar
Nice work. Cant wait to see the finished project.
2016 RG Custom Vivid Black
eddienelson is offline
post #3 of 16 (permalink) Old 07-12-2016, 05:26 PM
Q-Hog's Avatar
Just seeing this. I could've sent you a template I made for when I mounted mine.. looks good.
Q-Hog is offline
post #4 of 16 (permalink) Old 07-13-2016, 03:41 PM Thread Starter
psrumors's Avatar
The tour pak is wired up and lights work. Just waiting on the local Harley shop to get the AM/FM cable in and I'll have full functionality. I am also using the Custom Dynamics Magic Strobes and it strobes the light right in sync with the others
I am not sure if I am going to add speaker pods so I ran the harness through the floor of the tour pak. The QD mount makes for a great place to run wire though I will need to get some trim to keep the wire from chaffing on the edge.
Rather simple install really...just need to get the liner to finish it off.
I also want to get a set of the side marker light to get rid of the chrome trim.
ERod62 and DaleJ like this.
psrumors is offline
post #5 of 16 (permalink) Old 07-13-2016, 04:08 PM
That tourpak looks real nice.
How was it drilling the mounting holes in the tourpak plastic....did the paint chip out or did it make for a clean hole.
I'm in the process of drilling four holes in the lid of my tourpak to mount a luggage rack.....looks kinda scary!
Thanks.
squirrelsnest is offline
post #6 of 16 (permalink) Old 07-13-2016, 04:21 PM Thread Starter
psrumors's Avatar
Thanks.
Thanks! I am pleased with the way it turned out.
Drilling was very easy, no chipping and nice clean holes. I used sharp bits at about mid speed on a 2000 rpm drill. For the big hole where the plug goes I used a die grinder with some weird bit I have, drilled a hole and opened it up.
It really couldn't have gone any better....
psrumors is offline
post #7 of 16 (permalink) Old 07-13-2016, 04:27 PM
Thanks for your quick response....those holes in your tourpak look clean...no chip-out of the paint....now to get to my tourpak.....safe riding.
post #8 of 16 (permalink) Old 07-13-2016, 04:59 PM
z73421's Avatar
Looking good. I went with the late model king like yours but left the lights off. Now your are making me rethink that.
z73421 is offline
post #9 of 16 (permalink) Old 07-14-2016, 03:21 PM
Q-Hog's Avatar
All you have to do now is paint the black border of your light bar the same color as your bike.
Q-Hog is offline
post #10 of 16 (permalink) Old 07-14-2016, 05:10 PM Thread Starter
psrumors's Avatar
That's coming...
psrumors is offline
adding a HD king tour pak SEUGOT1 Equipment-RG 5 06-13-2018 08:13 AM
Adding run brake and turn to your King tour pack? steventammy Lighting 8 08-20-2017 04:37 PM
Want to trade my chopped tour pak for a King Tour Pak sloride Parts for Sale 4 05-15-2015 10:02 AM
king tour pak lights kimber6 Parts for Sale 5 04-22-2013 01:27 PM
WTB King Tour Pak or Chopped Tour Pak- BLACK jimmyray11349 Classifieds Archive (3 months old+) 0 06-03-2011 10:29 AM
