Needs another Volt Regulator - Road Glide Forums
post #1 of 10 (permalink) Old 07-12-2016, 10:05 PM Thread Starter
Darreldanger's Avatar
Any body else havin problems with their voltage regulator? I am needing another after mine going bad last weekend. I already have the recalled regulator installed by the dealer 2 years ago now I need one again.....
Darreldanger is offline
post #2 of 10 (permalink) Old 07-12-2016, 10:09 PM
The Volusianator's Avatar
Right now I'm overcharging, undercharging but running 14v most of the time, of course every time I've brought it in, they've tested it and said everything is running fine. Ugh
The Volusianator is offline
post #3 of 10 (permalink) Old 07-13-2016, 06:34 AM
What are the symptoms of a a crapped regulator. For example "it is charging at 14v most of the time. Does your voltage decrease at idle? Mine goes down to 13v at idle after the bike is warmed up, but runs at 14v when riding.
grambo is offline
post #4 of 10 (permalink) Old 07-13-2016, 09:25 AM
yes my 2011 went from 14 to 12 volts and already did the recall so took it in they suspected another bad regulator but after 1/2 hour they said the stator was bad they replaced it and then said o and the regulator was also bad what a joke
tampa-roadglide is offline
post #5 of 10 (permalink) Old 07-15-2016, 09:09 AM
mouser58's Avatar
I replaced mine with aftermarket and working great.. My original started with overcharging, then undercharging, then working fine.
2012 Ultra...Stage 1...Vance & Hines Power Duals,SE Night Sticks, V&H Digital, Stock air box with larger fliter..
mouser58 is offline
post #6 of 10 (permalink) Old 07-15-2016, 09:58 AM
Paul's Road Glide's Avatar
A couple of symptoms I noticed when mine started to crap out is the voltage meter steadily decreased down to 10v, each time I turned it on it started harder and slower. My check engine and battery light came on. While riding the volts would not go back up to the 13-14v like it should be indicating.
Those were the things I noticed when it crapped out/started to crap out.
....and of course I did the test to find out exactly what it was. replaced it about 2 years ago and it's been fine. BTW, this is my 3rd regulator. 1st one replaced under warranty.
Paul's Road Glide is offline
post #7 of 10 (permalink) Old 07-15-2016, 05:07 PM Thread Starter
Well, on mine the voltage would drop for a while then return to a normal 14.5 volts. It did this for about 3months or about 1500 miles then it kept doing it more often til it died completelynd ran my battery down
post #8 of 10 (permalink) Old 07-15-2016, 06:13 PM
VikingRider's Avatar
I had mine replaced with the CompuFire 40 amp 3-phase charging system. Best money spent on the old hog!
FLTRSEI2
VikingRider is offline
post #9 of 10 (permalink) Old 07-16-2016, 08:22 PM
Is regulator replacement a simple unbolt, plug and play?
grambo is offline
post #10 of 10 (permalink) Old 07-16-2016, 08:37 PM
kouack's Avatar
Yes, electric cycle sales a very nice unit and cheaper than the HD one and way more solid.
Envoyé de mon GT-P5113 en utilisant Tapatalk
kouack is offline
Needs another rotor Darreldanger Do-IT-Yourself 6 10-23-2016 08:00 PM
Replaced Fried Stator, Volt Regulator 15 RG.... maddmoe Do-IT-Yourself 13 08-01-2016 01:32 PM
Another Voltage regulator gone bad!!! denis75 *General Road Glide Discussions/Pictures 26 05-31-2012 02:20 AM
HD's 12 volt air pump. Howardsternspenis Aftermarket Accessories 4 01-29-2012 08:40 AM
06 ROAD GLIDE volt gauge rdbateman Troubleshooting for Road Glides 2 10-13-2010 08:24 PM
