Whirring Noise - Road Glide Forums
 2Likes
  • 2 Post By PGR
post #1 of 8 (permalink) Old 07-18-2016, 12:49 PM Thread Starter
Hiram's Avatar
Whirring Noise
New bike. At 150 miles or so, bike developed a whirring noise between 1800-2200 rpm. Sounds like its coming from rear and initially believed it to be a bad tire, but its RPM specific and only when there is a slight load, no noise with clutch pulled in and moving or at full throttle. I'm pointing a finger at the primary and trans. I checked the trans fluid, the level is fine.
Any ideas what may be causing it?
2016 Road Glide Special
Hiram is offline
post #2 of 8 (permalink) Old 07-18-2016, 12:59 PM
PGR
PGR's Avatar
Take it to the dealer and let them look. Warranty is 1000 times better than us. The internet should be your last resort when you have a warranty
ChromeSpark and Lord Vader like this.
Ron..........................
PGR is offline
post #3 of 8 (permalink) Old 07-18-2016, 08:44 PM
Well, ya know what the dealer will say, "That's just normal engine noise." I would be surprised, pleasantly surprised if the dealer is reasonable about it.
grambo is offline
post #4 of 8 (permalink) Old 07-19-2016, 08:50 AM Thread Starter
Hiram's Avatar
Fortunately, I have 2 years to drown it out with the radio before factory warranty ends. Its going back asap if it gets worse.
Hiram is offline
post #5 of 8 (permalink) Old 04-18-2018, 09:03 PM
The Balancers off the crank make a bit of that sound...I notice it on my 2018 and also on my wifes 16 slim....I guess its a small price for smooth.....
Garry1951 is offline
post #6 of 8 (permalink) Old 04-18-2018, 09:14 PM
Thermodyne's Avatar
Ya, one of the M-8's I test rode made some noise in the 2000-2500 range. High speed gear whine is what it sounded like.
I'll bet a nickel that its crank wobble making the balancer sing.
Thermodyne is offline
post #7 of 8 (permalink) Old 04-19-2018, 09:53 AM
hddan's Avatar
The dealers are like computer support help. Instead of telling you to reboot or explain that it is your fault, they will tell you that they all make the noise, or they will tell you (my favorite) that they cannot duplicate your issue and believe me Harley Davidson will absolutely do NOTHING to help you. They will only help when the NHTSA makes them have a recall.
hddan is offline
post #8 of 8 (permalink) Old 04-19-2018, 11:25 AM
Rear wheel bearings in proximity to fail maybe..... they act weird even once failed. When it happened on my Dyna I had a similar behavior on the rear because only one of the 2 failed, so I was able to ride 40km to home just managing the throttle in a range where the load was maybe on the remaining good bearing and was not resulting in noise or vibration.
Anyhow, bike is new so let the dealer deal with it
Beaver is offline
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 05:23 AM
Funny Whirring Sound From Head Unit (I think) When Ignition Switch Is Turned On HarleyLance Audio 9 01-27-2014 11:15 AM
chirping noise on deceleration cballjr54 Troubleshooting for Road Glides 13 10-21-2010 07:46 PM
New upgrades, new noise ? dhhen Troubleshooting for Road Glides 5 07-25-2010 09:00 AM
Front Fork Clunking Noise joke *General Road Glide Discussions/Pictures 12 05-01-2010 08:22 AM
