Drive belt tension - Road Glide Forums
post #1 of 3 (permalink) Old 01-29-2013, 10:00 PM Thread Starter
avidcycler's Avatar
Drive belt tension
Knowing what dimensions the shop manual states for drive belt tension (5/16"-3/8" of deflection with 10lbs. of upward force, without rider), my question to all is... does everybody run theirs that tight? Is there an unofficial "looser" dimension that most use or is it more beneficial (i.e. longer belt life) to use the factory specs? I also have a Buell Cyclone and everybody on the Buell forum say they run their Buells' belts "scarey" loose.
Thanks in advance.
2003 Anniversary Edition. 95" stage II, lowered 1" front & 1.5" rear with Progressive mono's & 444's, King Tour Pak w/quick detach mount, 10" mini apes & 11" Madstad.
avidcycler is offline
post #2 of 3 (permalink) Old 01-29-2013, 10:49 PM
staush's Avatar
Belt
Have always run my belt at factory specs.Never a problem with 2 of them(baggers) with 60K on each. They say a loose belt will deflect too much and snap and or jump sprocket teeth. They are strong, keep it tight to specs.
staush is offline
post #3 of 3 (permalink) Old 01-29-2013, 11:23 PM Thread Starter
avidcycler's Avatar
Ok... that makes sense. Just came in from the garage... was comparing the RG's belt with the Buell's. They ARE totally different beasts! Thanks!
Drive belt tension Morningwood Do-IT-Yourself 2 03-12-2018 09:06 AM
Drive belt tension Chuck1073 *General Road Glide Discussions/Pictures 9 10-18-2016 10:03 PM
monroe air ride & belt tension tigger26976 Suspensions 9 12-11-2013 05:20 PM
Drive Belt Wont Hold Tension adrenilinecrash Wheels and Tires 17 04-02-2013 12:42 AM
belt tension, axel torque?? kentucky cowboy Wheels and Tires 6 03-31-2013 11:00 AM
