Changing out the rocker tops - Road Glide Forums
post #1 of 8 (permalink) Old 02-04-2013, 08:39 PM Thread Starter
i am looking at changing the rocker tops for black powdercoated ones. any advice or pictures would be great!
harley hauler is offline
post #2 of 8 (permalink) Old 02-05-2013, 05:49 AM
mitchdm's Avatar
I highly recommend using the service manual ~ this is not a difficult task but the manual is very helpful ~ just double check the gaskets are installed correctly as you are installing the rocker tops ~
mitchdm is offline
post #3 of 8 (permalink) Old 02-05-2013, 07:59 AM
Hullhorr's Avatar
What Mitchdm said! As mentioned its not real difficult. The 3-top screws on the rear cylinder left side are difficult to torque because of their location. Be ready for that. I torqued mine by feel. They make a special wrench for those bolts although you don't have to use it, but it does make it easier.
You are going to need to remove the fuel tank. Try to run as much fuel out of it before removing or siphon it out. The lighter the tank the better.
2009 FLTR MOP
Hullhorr is offline
post #4 of 8 (permalink) Old 02-08-2013, 12:03 PM
yamahoe72's Avatar
sorry to jack the thread but are replacing the bottom rockers difficult?
2012 Road Glide Custom, Denim black, 14" Carlini Evil Apes, V&H Dresser Duals, Rhinehart slipons, Air Ride, Banana Boards, PM shift & brake levers, Cyclesounds speaker lids, Sony MS60, JL amps, Hertz HCX's, Meancity Cycles seat, lots of black
yamahoe72 is offline
post #5 of 8 (permalink) Old 02-08-2013, 12:48 PM
93-331-29psi's Avatar
I'm down for helping, if you need, once you decide to do it
93-331-29psi is offline
post #6 of 8 (permalink) Old 02-08-2013, 07:37 PM Thread Starter
will take any and all the help I can get! I will let you know when i get the courage up!
post #7 of 8 (permalink) Old 02-09-2013, 02:55 AM
mitchdm's Avatar
No ~ same advice ~ service manual ~ I have done mine on a 10 ultra ltd 3 or four times ~ powdercoat/top end/etc... Service manual and take your time ~ proper gasket alignment is a must....
mitchdm is offline
post #8 of 8 (permalink) Old 02-10-2013, 10:59 AM
garvin90's Avatar
Just did mine last week when I got em back from the PC guy. Put some oil on your finger and lube between the gasket and the cover so it seats right and doesnt move. Check your gasket placement once you drop it on(pretty easy since if they move it will stick out) and both sides should be on within 10 minutes. 20 if you dont read the manual or are "the most non-mechanical person" (sorry danny ). Make sure you dont over torque them as it can cause them to warp but as long as your not trying to play Mr. Universe, you should be fine.
@yamahoe72 As far as changing the bottom out, thats a bit more because of yours rockers attached to that plate. Check your service manual for that and it gives some really nice details on doing that bottom plate, both for dissassembly and reinstallation.
2012 Chrome Yella!
garvin90 is offline
Changing out Harley radio for single DIN GPS? drjterrell *General Road Glide Discussions/Pictures 0 06-16-2015 05:25 PM
Rock n Tops Sixnine68 *General Road Glide Discussions/Pictures 3 01-31-2014 02:04 PM
April American Bagger article on changing out the front end 1346wildcat Suspensions 0 03-10-2013 02:00 PM
19' apes, spiked tops kinda like yaffe but custom built. marvo75 Sold 14 09-11-2012 01:58 PM
