Garage Door Mod - Road Glide Forums
 5Likes
post #1 of 11 (permalink) Old 09-29-2016, 11:18 AM Thread Starter
CHOP!'s Avatar
Garage Door Mod
I am hearing that there is a way to set your garage door to open with you headlights. Does anyone know if this is real, how to do it????
CHOP! is offline
post #2 of 11 (permalink) Old 09-29-2016, 11:22 AM
08Zinc's Avatar
Remote Control Garage Door Opener Receiver | Garage Openers | Official Harley-Davidson Online Store
I'm sure someone has a non-Harley way of doing it, but I have used these for years.
Byoung330 likes this.
Blessings, Zinc -
08Zinc is offline
post #3 of 11 (permalink) Old 09-29-2016, 11:37 AM
Mischief's Avatar
I purchased an extra trip odometer switch and soldered wires to an extra garage door opener. Do a search and you will find a lot of people who have done on here. Cost of parts less than $10 (plus an extra garage remote)
the opener is mounted in my tour-pak and the switch is mounted in-between my speedo and tach. I always find it funny when I see someone at the dealer pressing it to see my odometer reading and nothing happens
Brewiz likes this.
2012 FLTRU
Mischief is offline
post #4 of 11 (permalink) Old 09-29-2016, 12:25 PM
RGKen's Avatar
What you are hearing is that the garage door opener is installed under the fairing and is wired into the headlights for power. So when you hit your bright/dim switch it activates the garage door opener. This is the way the HD one works but you can also wire your own opener in this way or use the push button switch that others have mentioned.
2018 FLTRXS
RGKen is offline
post #5 of 11 (permalink) Old 09-29-2016, 12:43 PM Thread Starter
CHOP!'s Avatar
Thanks. I will have to wire one up...
CHOP! is offline
post #6 of 11 (permalink) Old 09-29-2016, 01:01 PM
Stick_FSMC's Avatar
I mounted the garage door opener in the Speedo/Tach cluster and put a trip meter switch in there like others have suggested.
Here's a photo of how it looks when finished.
Power for the unit comes from the bike and the new trip meter switch activates the normal push button as before. It's been there now for about 2 years with no problems.
Stick
USAF 1980-84
Stick_FSMC is offline
post #7 of 11 (permalink) Old 09-29-2016, 01:08 PM
UT_Larry's Avatar
I got the HD opener. The non HD is called Flash2pass. It is a great mod. Just funny when adjusting headlight alignment & you keep opening & closing the garage door.
UT_Larry is offline
post #8 of 11 (permalink) Old 09-29-2016, 01:22 PM
KennyD104's Avatar
where did you get the trip meter switch.
Ken
2015 Road Glide Standard - Denim Black - 14" Factory47 Malo Bars - 12" LRS Stingray Medium Tint Shield
KennyD104 is offline
post #9 of 11 (permalink) Old 09-29-2016, 02:17 PM
Stick_FSMC's Avatar
I got it from Harley. there's two parts to it. It's the switch and the switch cover. I don't remember the part numbers, but I'll see if I can find my paperwork on it when I get home. Should be easy enough to find though, I just asked at the parts counter.
Stick
USAF 1980-84
post #10 of 11 (permalink) Old 09-30-2016, 04:06 AM
I just mounted an extra opener under the lefthand cubby lid, attached to the hinge. Takes about two second to flip the lid and hit the switch going up the driveway.
With all the new vehicles with built in HomeLink or other remote access systems, almost everybody has extra openers now.
2016 Cosmic Blue Pearl RGU
2002 883R Sportster
Kennyd is offline
Garage door mod or HD unit on a 17' info request Easyryder01 Tech Area 5 05-18-2017 12:55 PM
My free garage door opener mod Timinfla2 Do-IT-Yourself 18 08-28-2015 12:55 PM
Very slick garage door opener, mo-door roadie13 Aftermarket Accessories 1 03-31-2015 07:50 PM
My Garage Door Opener Mod. Stickman81 Do-IT-Yourself 7 03-26-2013 08:40 PM
mod leads to mod after mod, i need to be locked up (-: mroach *General Road Glide Discussions/Pictures 14 07-29-2012 09:04 PM
